Tigershark front install
Old Jan 12, 2008 | 09:43 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by davcose01
I just received my Tigershark front facia from 21st Century Musclecars. It was easy to pull the old front end off. The new one lines up fairly well, but Im fairly **** when it comes to fender and hood gaps. Anybody out there that has installed there own please post whether you where able to get really good alingment without any filling or mods to the new front facia. I have just a little more gap at the corners where the hood meets that I would like and the front facia sets a little taller than the front edge of the stock hood. Thanks any info would be helpful
A few tricks of the trade. The front nose has an adjustable edge that can be raised or lowered so that the fascia and the hood will align correctly.
For even more perfection, you can get some large size washers and shim it from underneath to get it perfect.
I am in the midst of converting my coupe to an FRC and outting on my tiger shark nose and mcm hood plus a bunch of ACP body parts.
Old Jan 12, 2008 | 09:50 PM
NemesisC5's Avatar
NemesisC5
Default Here's Mine
Old Jan 12, 2008 | 10:27 PM
Junkman2008's Avatar
Junkman2008
The TS sitting higher than the hood was the problem I had when mine was installed. I adjusted all the post and that thing wouldn't line up for nothing. Then I got to looking at the the bolts that hold the hood onto the hood mounting bracket and saw that ONE of those bolts is an adjusting bolt. Sure enough, that did it. It's not perfect on the sides so I'll need to do some more adjusting but that awful alignment issue in the front is gone.
Do you have fog lamps?
Old Jan 12, 2008 | 10:31 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Slide a few large washers under the low areas to make it fit better. That's how GM does all of your fenders, etc..
Old Jan 12, 2008 | 10:32 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
No real issues on mine... fits the fender/wheel well area better than oem.
Old Jan 12, 2008 | 11:10 PM
davcose01's Avatar
davcose01
No fog lights, I agree there are alot of adjustments, I spent the day working this one over and it fits much better than when I started. It is not a bolt on install if you want it to look correct. I also worked the center out some with 40 grit paper, the facia is very thick there and some material can be removed, also have a good friend in the body buisness.
Old Jan 12, 2008 | 11:30 PM
jdmvette's Avatar
jdmvette
Night Owl for life
so you guys are installing the facia yourselves?
i'd like to save the cost of a shop doing it, is it fairly straightforward?
Old Jan 13, 2008 | 12:52 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Yeah, it is pretty easy. You'll have to pull off your front fascia and then check the fit of the tigershark and then send it out to get painted and then install it.
Not sure what color you car is and whether or not you'll need to blend paint into the hood and fenders.
Old Jan 13, 2008 | 02:11 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i doubt i would need to. my quarters were panel painted and they match perfectly.
so if the test fit had issues, i'd probably have to let the body shop deal with it?
Old Jan 13, 2008 | 06:36 AM
Junkman2008
The shop that did mine has a guy who specializes in after market kits. He said that he has done some that were a major PITA. He then started describing how much work he did on mine but at the end said that this was one of the more pleasant experiences that he has had with an after market install. For what it's worth...
Old Jan 13, 2008 | 10:21 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Should be straight forward then for you. They have remolded the original ones from a few years back.
The new ones are really nice and fit up very well or at least mine did.
Old Jan 13, 2008 | 02:03 PM
Flyskate's Avatar
Flyskate
Not to get off topic, but I've seen some tigersharks with zo6 screen material for the grill and fog lamps, does anyone know where those are available?
Old Jan 13, 2008 | 02:48 PM
  #33
ajg1915's Avatar
ajg1915
St. Jude Donor '08
There either custom done or repainted silver. I asked the same questions of a couple membes who had done that to their front screens.
I have a dark colored car, Navy Blue and want some contrast and will re-spray the screens silver to match some paint accents that i plan to do.
Old Jan 13, 2008 | 04:50 PM
  #34
Junkman2008
The screens come with the TS in black. You can paint them if you like.
Old Jan 13, 2008 | 07:40 PM
  #35
Flyskate's Avatar
Flyskate
I believe some folks have gotten zo6 screen material, I was wondering if it was commercially available for the tigershark.
Old Jan 14, 2008 | 12:24 AM
  #36
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Don't think so. Anyone that has done an after-market material has done so on their own.
Old Jan 14, 2008 | 10:27 AM
  #37
Cobra4B's Avatar
Cobra4B
The TS screens are black extruded metal... I like them. A few guys like GBVette have sourced out Z06 screen and used that.
To Tigershark front install
Old Sep 9, 2008 | 12:48 PM
  #38
btriplec's Avatar
btriplec
Default wHEELS
Originally Posted by ChasC5
Good Choice
What kind of wheels/tires/size do you have on your Vette? Nice!!!
Jeff
Old Sep 9, 2008 | 01:21 PM
  #39
Birdman's Avatar
Birdman
Originally Posted by 1BAV
Mine lined up real good. It was done at a body shop so I don't know how difficult it was or if there were problems. I am very satisfied with the results though!
About time I saw a pic with the emblem on the TS bumper! I love the way they look and if I cold afford it, I'd get one, but it seemed a little empty without the emblem.
Old Sep 9, 2008 | 06:30 PM
  #40
YELLOHHH's Avatar
YELLOHHH
Less is more. Looks cleaner without the emblem. Anyone who doesn't know what kind of car it is doesn't care what kind of car it is.
