So I have the passive key fob for my 99 and it has been acting up for quite a while. If i am anywhere within a 20 foot radius of my car it will just continue to lock and unlock repeatedly. Even when I park my car and take the key out of the ignition, if i dont open the door for a min or so it will lock me in then i have to wave the fob around till it unlocks me or else the alarm will sound. I know the easy answer is to just turn the passive function off, but I like it and I want it to work correctly. Anyone got any answers for this one? thanks in advance!!
I think the problems you're experiencing are the main reason GM discontinued the active/passive FOB. It was a good idea, but NOT well thought out before being put into production.
As far as I can tell there is no way prevent what what you're going through.
Do yourself a favor and just turn it off. I did. A long time ago.
It sounds like the culprit is the passive switch on the remote. You could try just ordering a new fob and that should take care of the issue you are having.
Ordering a new FOB will not solve the problem. The OP wants the "Passive" feature to be active. As long as the switch is "On", he will continue to experience what he's going through now.
I've reread the original post and I disagree with you. I believe the fault the original poster is describing has to do with a failure of the passive switch on the fob, not with the car or the receiver. The passive switch was the weak design link in terms of random operation and unpredictable behavior. I maintain that replacing the fob with one with a functioning switch will allow him to go back to the passive features without all the unpredictable behavior.
I used a passive remote on my '97 for five years. When it started acting up I replaced the fob and the operation returned to normal.
The continuous locking and unlocking as described is not normal behavior. That is a defective transmitter or dying battery.
none of the above sorry , the switch gets dirty , just move the switch back and forth several times and your good to go , i have turned several people on to this fix . simple your done
I believe the problem is in the transmitting range the Fob has, for this Fob, it goes a lot father, therefore if you are anywhere within that range, it will unlock or lock as the signal reaches the car or is lost from it. They fixed that issue on the C-6's with a very limited range of approximately 3 feet now. All C-6 Fobs have the passive built in with no selector to turn it off however I think the function can be turned off in the DIC.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I have it and it is turned off - period. I'll tell you why....
When I first got my '98 I thought this was a cool idea. I also had set the LOCK/UNLOCK function in the DIC to flash lights and horn.
I hang my keys on a hook inside the house right next to the door that leads to the garage. Apparently it was just barely within the range of the system and it would lock/unlock constantly - and of course - since I had set the system honk the horn and flash the lights, it would do that each time.
One night at about 2:00 a.m. - my wife elbows me in the ribs, I'm sound asleep....and tells me - "Your car is calling to you - could you please go see what SHE wants and tell her to SHUT-UP!"
Needless to say - I disabled the feature on the fob, and the flash lights/honk horn on the DIC.
I agree with Paul - it's possibly a faulty transmitter, you might be able to clean the contacts, or you simply might need a new transmitter.
The motion sensitive switch inside the FOB, combined with the distance it is from the car at the time it is "activated" (by motion) will cause it to transmit. The battery power will definitiely affect the range.
I got a new passive remote last summer... brand new,, I have the same problem. I have the car sitting in the garage, and the keys hanging at the front door and the doors lock and unlock constantly. It says that the remote should be at least 20+ feet away. Guess I should leave my keys at my neighbors house then.. I got fed up with it and just keep the passive off. I use to use it when I take the car to work, then when I walk away I'm not sure if it actually locked or not,,, it's more of a pain in the butt than anything.
ok.. thank you all for the input. I guess i will attempt moving the switch back and forth a few times but my guess is that chevy just didnt think when they made this one. My dads c6 works great. The fob i have now is only a year old and has done it since i've had it. Sometimes more then others. If I have to disable it i will...oh well
oak
The last time I replaced the batt in the FOB I cleaned it all with contact cleaner and a Q-Tip. That was 8 month back and my problem has not returned.
