HVAC Problem
Old Jan 13, 2008 | 07:00 PM
Silversides's Avatar
Silversides
Default HVAC Problem
Hi,
I just brough home a new to me 2002 vert. On the way home last night, my HVAC did some strange things. 42 outside and set on 72-76 inside produced hot and cold air coming through dash vents, Or same with cold air coming out of defroster. If set to 80, then you would get some heat, Or set to 70 or less, with (windoes down) you get a/c. You could set the mode manually and get a fair amount of heating or cooling . All fan speeds produced less than forceful air flow.
I've read ALL the posts, and haven't quite come up with this combo.
HELP!
Thanks,
Silversides
Old Jan 13, 2008 | 10:41 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Sorry to hear about those problems. If you find you need to replace the HVAC dash controller unit I have one for sale that I used in my car for several months...works fine, everything lights up and functions...$100 shipped.
Jerry
Old Feb 24, 2008 | 08:31 AM
The Panther's Avatar
The Panther
I have the same thing. I will set it to 76 and on the floor and ten minutes later it will be split between floor and defroster and the AC is on. I don't even try the Auto mode anymore because it keeps the AC on the whole time even with the temp set to 80.
Old Feb 24, 2008 | 08:42 AM
racetchr's Avatar
racetchr
Originally Posted by Silversides
Hi,
HELP!
Thanks,
Silversides
Everyone will have a different solution and trouble is, they are all possibile! But save yourself aggravation and make sure your freon level/press is correct. These cars are super sensitive to the proper amount.
Old Feb 24, 2008 | 08:58 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
First things first, pull up your codes and see what HVAC codes are there.
Hold the options button, press the fuel button 4 times, read the codes, then post them here. Need to see what codes you have before we can make a better diagnosis.
When mine was doing the same thing, it was the right side actuator that was the culprit. Don't remember the code it threw, but it was right there. Replaced the actuator, and all is well.
Here's a couple of links to the codes you might want to bookkmark:
http://www.gearchatter.com/index.php...95e5740a74d10d
http://www.corvettedoctor.com/2004_DTC_Codes.html
Pull the codes, and post them here, make sure you put an H or a C behind them so we know if they are current of not.
To HVAC Problem
