Rear suspension tools?
Old Jan 14, 2008 | 09:10 AM
555ss's Avatar
555ss
Default Rear suspension tools?
Can anyone point me in the right direction to get the correct pullers to remove the rear half shafts? The service manual calls out a slide hammer and several tool #'s.
I found out the left rear bearing and seal are gone, and I don't trust the local techs. (hacks)
Bob
Old Jan 14, 2008 | 10:26 AM
IM28702's Avatar
IM28702
They just pop right out. Take the nut off the outside by the lug studs, and that end just slides out of the hub. The end that slides into the tranny, just get a screwdriver, or wide chisel etc inbetween the tranny and CV joint, and pry outward. With the least of force, it will just pop out. Putting it back together, you can just pop it in with your hands.
Old Jan 14, 2008 | 12:22 PM
555ss's Avatar
555ss
Thank you IM28702,
The book makes it look like a PIA.
I was hoping some one who knew what it really took would reply.
Old Jan 14, 2008 | 12:31 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
It's simple and no slidehammers are required. I took mine apart last winter.
I looked for an internet link but couldn't find one. In a nutshell, you remove the bottom bolts of the shocks, unbolt the 2 inner bolts of the top A arm, pull the A arm towards you, and you're done.
You might also have to remove your calipers from their brackets and hang them up with zip ties. No brakeline removal.
Old Jan 14, 2008 | 02:04 PM
555ss's Avatar
555ss
now that is way easier than the book Thanks.
To Rear suspension tools?
