Crazy Speedometer!
Old Jan 16, 2008 | 12:37 PM
Black_6-Speed's Avatar
Black_6-Speed
Default Crazy Speedometer!
On my way to Florida a couple of weeks ago, my speedometer began malfunctioning. It just fluctuates all over the gauge. It seems to normalize when I am steadily turning left, or when the weight of the car is shifted toward the right side. As soon as I straighten the car, it goes crazy again. I hear there is a speed sensor at the transmission, but a sensor problem usually doesn't react to physical changes like the weight shift thing. Maybe a bad connection? The Corvette is a 1997 M6 with 13K miles.
Does anyone have any experience with this, or have any light they can shed on this problem? Thanks in advance!
Old Jan 16, 2008 | 12:40 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Old Jan 16, 2008 | 12:41 PM
bucwheat's Avatar
bucwheat
Old Jan 16, 2008 | 01:57 PM
bgreen83's Avatar
bgreen83
hahah, no clue. you should take a video and post it i think that would be hilarious. If it maxes out you should slow the video down and act like you went 0-200 in like 10 seconds
Old Jan 16, 2008 | 02:58 PM
Black_6-Speed
Old Jan 16, 2008 | 04:51 PM
1BAV's Avatar
1BAV
Cruise-In IX Veteran
Do you have any codes tripped? Mine was goofing up a while back when I was have EBCM problems. The speedo malfing up seemed to coincide with when the EBCM codes were tripping. I guess the two talk to one another when everything is working properly. I replaced the EBCM and the speedo hasn't acted up since.
Old Jan 16, 2008 | 09:12 PM
No idea what might be causing it, but will be to see if a solution is suggested.
Old Jan 16, 2008 | 09:35 PM
droq172's Avatar
droq172
I heard a fix awhile back but didn't give it a second thought I have never experienced the problem you are having. It sounds simple enough but disconnect you battery leave it off for 15 minutes and hook it back up. It may fix the problem.
Old Jan 16, 2008 | 09:41 PM
Junkman2008's Avatar
Junkman2008
Mr. Lau's Avatar
Mr. Lau
No no, not yet. Post a vid of it first like what bgreen said! it would be awesome
Old Jan 16, 2008 | 10:12 PM
Junkman2008
Funny, this is what my El Camino is doing right now. I know why but haven't fixed it yet. Until I fix it, my tach is my speedometer.
Old Jan 16, 2008 | 10:29 PM
JH's Avatar
JH
Sounds like a loose connection or corroded ground.
Old Jan 16, 2008 | 10:40 PM
maxvalley's Avatar
maxvalley
a 1997 with 13k miles, I think it's just excited it's going on a trip!
Old Jan 17, 2008 | 07:16 AM
Black_6-Speed
I'm not getting any DIC errors. I'll try unplugging the battery tonight.
Old Jan 17, 2008 | 01:17 PM
Black_6-Speed
I just went to lunch, and leaving the restaurant, the DIC started telling me to service TCS and ABS! The speedometer has been crazy for two weeks, and I drive the car every day, so I doubt the two are related. This is getting frustrating. I'm just hoping that when I leave work in a few hours, the TCS and ABS errors will be gone.
Old Jan 17, 2008 | 02:01 PM
bgreen83's Avatar
bgreen83
Looks like we might have a winner here!
To Crazy Speedometer!
