Just a quick question
Old Jan 17, 2008 | 03:06 PM
convertible lover's Avatar
convertible lover
Default Just a quick question
Looks like I am going to have to pull the intake to replace the oil sensor, do i have to drain the water? Does it go thought the intake at all? I Have read the howto's but do not see if you have to or not.Thanks. Jack
Old Jan 17, 2008 | 03:15 PM
Last C5's Avatar
Last C5
You don't have to mess with the water if you've already done a throttle body bypass.
Old Jan 17, 2008 | 03:23 PM
convertible lover
Not sure what that is.
Old Jan 17, 2008 | 04:01 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I could be wrong but I do believe you have to drain some if your removing the intake.
Old Jan 17, 2008 | 04:11 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
First off you do not have to remove your intake on your 2000 vert. its just ten bolts, you dont have to remove injectors or fuel line..Just have to move the intake forward about six inches. Ive done it several times.. last time took me 45 minutes start to finish..this is including replacing the oil sensor.
Old Jan 17, 2008 | 04:21 PM
convertible lover
Default now I am stuck
I have the intake loose, can raise it up an inch but can not get it to pull foward. fells like some thing is holding it. now I am stuck. Any ideas?
Old Jan 17, 2008 | 07:26 PM
Evil-Twin's Avatar
Evil-Twin
the two bolts under the cowl at the rear have to be held up with some tape in order to clear the block... there is an air manifold on the rear of the intake.. it has a very small hose ( make sure you put this back, it controls your AC vent managment, also another larger L shaped hose connector.
Old Jan 17, 2008 | 07:36 PM
Vega$Vette's Avatar
Vega$Vette
Map sensor on the rear of the manifold. Be careful taking it loose as it breaks fairly easy.
Old Jan 17, 2008 | 08:04 PM
convertible lover
Default Thanks for all the help
I finely have it apart just to find out I don't have a deep socket big enough to get it out. I will have to buy one tomorrow, and try to get it back together tomorrow. I think I read somewhere it is 1 1/8 deep socket. I am looking for that info now. But thanks for all you help. Jack
P.S. I did lose a little water out of one small hose I took loose, and I had to take the fuel line off it was to short.
Old Jan 17, 2008 | 08:18 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Thanks Bill! Glad you're back. That even sounds easier than the access hole in the cowl. '02 bought new, haven't had to do this yet.
To Just a quick question
