Puzzeling Climate Control Problem
Old Jan 17, 2008 | 11:42 PM
CircledWagons's Avatar
CircledWagons
From: Guess it & Win a Rock, s&h only $4.95 New Mexico
Default Puzzeling Climate Control Problem
My climate control on my 2000 Coupe works great, all the buttons work, it heats and cools fine, but everytime I turn the key and start to drive, the unit always defaults in the "outside air to inside" mode. This would be great on the open road in the pines, but it's a pain when I am in the city and breathing morning exhaust fumes.
Anyone have this issue and know an easy way to fix it so the hvac control defaults to the "circulate air from inside" mode when the unit starts?
- Craig
Old Jan 17, 2008 | 11:45 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You can try to set it in memory with your key fob, Just set the unit where you want it and then press and hold the memory button on the door for the fob you are using.
Old Jan 17, 2008 | 11:54 PM
CircledWagons
Outstanding Advice - Works like a charm.
Thanks Bill
Where did I put that Owner's manual?
To Puzzeling Climate Control Problem
