4 Post Lift
Old Jan 18, 2008 | 12:59 AM
MorpheusGPR's Avatar
MorpheusGPR
Default 4 Post Lift
What brand 4 post are you using and any photos of it?
Old Jan 18, 2008 | 01:34 AM
Novat_99's Avatar
Novat_99
Rotary Revolution XLT...very happy with it
Old Jan 18, 2008 | 09:10 AM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Direct Lift
Old Jan 18, 2008 | 09:42 AM
bkemp's Avatar
bkemp
Bend-Pak HD-9, very good quality 4 post lift. I'm very happy with mine.
Old Jan 18, 2008 | 11:47 AM
hotwheels57's Avatar
hotwheels57
If you search this forum (in red banner) in C5 tech, you'll find this has been discussed maybe a thousand times or so ...use keywords "lift".
Remember, your pride and joy will reside on the lift and you will be under the lift, so do your due diligence. My current lift is a BEND PAK HD9...
http://i114.photobucket.com/albums/n...p011608005.jpg
This discussion was just posted this week...
http://forums.corvetteforum.com/show....php?t=1915366
Old Jan 18, 2008 | 11:54 AM
34RedRage's Avatar
34RedRage
double 2 park for me... absolutely love it....
Old Jan 18, 2008 | 01:29 PM
V-man's Avatar
V-man
St. Jude Donor '08
These all look great.......how high are your ceilings?
Old Jan 18, 2008 | 01:32 PM
hotwheels57
Twelve foot (or more) is probably optimal for full lifting height of almost any vehicle, but you could get by with less. You wouldn't be able to lift to full lifting height, but many have a four post lift and use a creeper stool to work beneath their lifts.
Old Jan 18, 2008 | 03:36 PM
Novat_99's Avatar
Novat_99
My ceiling is just about 14'...that's why I went with the XLT model. It has 6'4" of rise lift compared to the standard model's 5'3" rise.
Rotary has a nice ceiling height calculator here:
http://www.revolutionlifts.com/Ceiling.asp
Min height for a 4-post tends to be around 10' range.
I've since forgiven them for putting a Mustang convertible in the pic
Old Jan 18, 2008 | 04:33 PM
LMBZ4ME's Avatar
LMBZ4ME
Bend Pak HD9 for me too!
Old Jan 18, 2008 | 04:36 PM
danshill's Avatar
danshill
2021 C2 of the Year Finalist - Unmodified
I've been looking at 4 post lift options and am just about ready to make my purchase. I've determined that the ceiling height required has more to do with how you plan to use it.
I plan to use it to park 2 Vettes, an 01 and a 65. The height from floor to the open garage door is 109 inches. According to my calculations, I will have about 4 inches of clearance with the garage door open.
I'm going to buy the ProPark 7 LL or ProPark 8 unit.
Old Jan 18, 2008 | 04:57 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
I have an All American Lifts (www.allamericanlifts.com) 4-post. It is essentially a copy of the Backyard Buddy lift at a lower price. The principle differences between it and most of the other lifts you will see here are (i) its use of solid posts (rather than C-chanel posts) with cross-bars which envelope the entire post (and thereby capture/trap the safety locks so they can't slide off if the lift is tilted), (ii) it's ~6"-9" wider than the others, and (iii) its use of I-beams topped by steel plates for the longitudunal members (rather than C-shaped bent steel sheets). It's more expensive than the typical 4-post lift, but the IMO safer design was worth the additional cost to me.
For height, I fit a C5 coupe and a C6 'vert stacked under ~9'3" trusses.
Old Jan 18, 2008 | 06:04 PM
lh4x4's Avatar
lh4x4
I also have a Bend Pax HD9W. It is taller and wider than the regular model. I have a 12'1" ceiling in the garage. With the higher lift, I can walk under it with out hitting my head. I'm 6'2" and the rails are 6'6" with it raised fully.
I haven't learned to post pictures yet. I have used the lift for two years now without any trouble. It is due to have the cables adjusted. I installed it my self and it was a very easy job.
Old Jan 18, 2008 | 07:10 PM
34RedRage's Avatar
34RedRage
i have a 10' 3" ceiling and i can lift any vette to its highest point of lift and have about 4" to spare.
Old Jan 18, 2008 | 10:17 PM
CoastalRAP's Avatar
CoastalRAP
I have the Direct Lift. I put it sideways so it would clear.
Old Jan 18, 2008 | 10:23 PM
oaks99's Avatar
oaks99
direct lift 9000 lb from greg smith equipment company , great lift no problems in the 2 years i have had it
oak
Old Jan 19, 2008 | 11:31 AM
MorpheusGPR
Well I went to the local Greg Smith and looked at their unit. I liked the price a lot better, but just could not get over the over seas steel and the non boxed posts. I ended up deciding to go with the Back Yard Buddy. I am told its about 9-12 weeks for production. Its going to be a tight fit with only 9' to work with, but I have talked with them and measured the cars and should just clear. I am planning to call to have my garage door (single) adjusted and modified to go up higher before it bends and moves in.
To 4 Post Lift
Old Jan 19, 2008 | 11:59 AM
hotwheels57
What did you think of the BACKYARD BUDDY salesman? If it's the same guy I spoke to, his attitude turned me off to their product.
Old Jan 19, 2008 | 12:03 PM
csexton's Avatar
csexton
Chuck
Old Jan 19, 2008 | 02:09 PM
tellefan's Avatar
tellefan
He is an idiot! We looked at his lift two years ago at Bloomington Gold. Super Lifts had a display near his. So...... we checked his out. After learning more than I ever wanted to know, I bought a Panther lift from the famous auction site. It's the same as any of the other import lifts. It just has a different label. I've been real happy with it. If you do buy a four post lift be sure to get the aluminum ramps and a second jack tray so you can remove all four wheels at one time. David
