[Z06] what would
Old Jan 18, 2008 | 04:53 PM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default what would
What would you guys do?? Should I get my 4 wheel alignment done now, are wait till I get new wheels and tires ????
Old Jan 18, 2008 | 04:55 PM
Bigstik's Avatar
Bigstik
Its the same money either way, isn't it???
Old Jan 18, 2008 | 04:57 PM
jmc12's Avatar
jmc12
Yes but I don't know if it will change when I get new wheels and tires...
Old Jan 18, 2008 | 07:45 PM
TEXHAWK0's Avatar
TEXHAWK0
If the shop does it right, the alignment should not change. When you mount the new tires, you might have the tire shop check the wheels to make sure they are true.
Old Jan 18, 2008 | 07:49 PM
Bob CTS's Avatar
Bob CTS
I would wait unless it pulls hard or the caster/camber is out. If the tires are worn severely it can throw off the alignment a bit. When I worked at the tire shop I always recommended getting an alignment when new tires are installed, unless of course the customer hit a pot hole and something with the car is wacky.
Old Jan 19, 2008 | 03:47 PM
03z06BLK's Avatar
03z06BLK
how long you waiting?
Old Jan 19, 2008 | 04:27 PM
TEXHAWK0's Avatar
TEXHAWK0
The alignment is set from the wheels, not the tires. The tires do not control the alignment, the suspension does. If you get new tires before you check the alignment, I would not drive very far. If they are very far out of alignment, you will start to see a wear pattern in just a few hundred miles.
Old Jan 21, 2008 | 07:42 AM
jmc12's Avatar
jmc12
Thanks: I am going to wait tell my new wheels and tires get here, should be the first or second week in Feb.. Thanks again...
Old Jan 21, 2008 | 10:27 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have always heard its best to do it with the new wheel/tire combo..... coming from quite a few people that worked at tire shops/mechanics. If your gonna have your new stuff in the next couple of weeks I dont see any harm in waiting.
Old Jan 21, 2008 | 11:30 AM
jmc12's Avatar
jmc12
Yes I am going to wait till I get the new stuff, the ZZZZ is not my DD so I will put it away untill then.. Thanks all...
To what would
