GMVIS report?
Old Jan 18, 2008 | 09:45 PM
95ttoplt1's Avatar
95ttoplt1
Default GMVIS report?
Can someone run a GMVIS report for me? I can PM you the vin. I'm really just interested in the RPO codes.
Thanks in advance
Troy
Old Jan 20, 2008 | 04:45 AM
95ttoplt1's Avatar
95ttoplt1
Anyone??
Vin number is 1G1YY22G0Y5122995
Old Jan 20, 2008 | 08:33 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Send a PM to forum member GMautotech. You can find his profile here:
http://forums.corvetteforum.com/member.php?u=221526
Old Jan 20, 2008 | 08:35 AM
CTSV OWNER's Avatar
CTSV OWNER
Ready to help on a Sunday morning.
VIN 1G1YY22G0Y5122995
VEHICLE BUILD
Merchandising Model : 1YY07 -2000 CORVETTE COUPE
Gross Vehicle Weight Rating : 1687 kg (3720 lb) Order Number : CGQF65
Build Date : 03/09/2000 Build Plant : 1Y5Y - BOWLING GREEN
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AAB AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS AQ9 - SEAT FRT BUCKET, PASS, DRIVER
BGR B34 - COLOR-KEYED FRONT FLOOR MATS -CARPETED
B84 - BODY SIDE MOLDINGS CJ2
C2L - DUAL REMOVABLE ROOF PANELS DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS D42 - REAR COMPARTMENT CARGO COVER
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - FEDERAL EMISSIONS
F45 GU6 - REAR AXLE 3.42 RATIO
IL3 JL4
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63
LS1 MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NF2 - FEDERAL EMISSION SYSTEM
NK4 - LEATHER WRAPPED STEERING WHEEL N37
N73 R9Z - CONTROL-SALES ITEM NO. 100
T82 - TWILIGHT SENTINEL HEADLAMPS T96 - FOG LAMPS
UN0 - AM/FM STEREO W/CD PLAYER UV6
UV7 UZ6
U1S U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL V49
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG
YGH 1SA - OPTION PACKAGE 01
11U - LIGHT PEWTER METALLIC 92I - MED GRAY INTERIOR TRIM
923
© 1998-2005 General Motors Corporation. All Rights Reserved.
Dave
Old Jan 20, 2008 | 01:10 PM
95ttoplt1's Avatar
95ttoplt1
Dave
Thanks Dave, that is super cool.
Does anything stand out in there as a cool option to have?
I see that it has MM6 and MN6, I thought these were 2 different transmissions?
Ok I got on Corvette action center and filled almost all of the rest in, any one know what BGR is??
AAB - Memory, Driver Convenience Package
BGR
CJ2 - HVAC System, Air Conditioning, Automatic Temperature Control (Dual Zone)
F45 - Chassis, Selective Real Time Damping
IL3 - Trim, Interior Design (L3) (Base w/ AQ9)
JL4 - Control, Active Brake
K63 - Generator, 110 Amp
LS1 - Engine, Gas, 8-Cylinder, 5.7L, MFI, Aluminum (VIN G)
MM6 - Transmission, Manual 6-Speed, Borg Warner
MN6 - Merchandised Transmission, Manual 6-Speed Provisions
N37 - Steering Column, Tilt, Telescoping
N73 - Wheel, Custom Sport Magnesium
T96 - FOG LAMPS
UV6 - Display, Head Up
UV7 - Antenna, Windshield, Rear Lift Window, Radio
UZ6 - Speaker System, 6, Quad Front Door Mounted, Dual Quarter Mounted
U1S - Changer, Remote Compact Disc
V49 - License Plate Frame (front)
XGG - Tire, Front, P245/45R17-89Y, BW TL SBR HW4, EMT
YGH -Tire, Rear, P275/40R18-94Y, BW TL HW4 SBR, EMT
923 - Trim Combination, Leather, Lt Gray
To GMVIS report?
