Cold weather reminder
Old Jan 18, 2008 | 10:17 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Cold weather reminder
For those of you experiencing unusually cold weather, you may notice that you're milage is suffering. Make sure you're tires are properly inflated. The excessively cold weather can cause low pressure. Since the temperature drop last week, my tire pressure dropped from 30lbs to 25 lbs (no leaks) robbing me of 15-20% milage. Since filling up, i'm back to normal milage.
Old Jan 18, 2008 | 11:18 PM
rws.1's Avatar
rws.1
every 10 degrees means a drop of about 1psi
Old Jan 19, 2008 | 12:18 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
yup, that would explain things. we went from a toasty 75 degrees to around 40 ish (during the day)
Old Jan 20, 2008 | 10:32 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Default Timely reminder...
This is a timely reminder for all of our vehicles, vettes and other DD's. I notice more cars around town with flats this time of year than the rest of the year. While you are checking your tires, it might be a good time to have someone check you brake, turn and running lights to make sure they are all working.
Old Jan 20, 2008 | 10:33 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Great advice or reminder to all
Old Jan 20, 2008 | 11:55 PM
427435's Avatar
427435
You're correct about colder temps lowering tire pressure. My tire monitors alarm and show 24 psi for until I've driven it a few miles in 30-40 degree weather.
However, a lot of your MPG drop is from the cold temps affecting other things besides tire pressure. The fuel enrichment circuit is on longer, seals are tighter, transmission/differential oil is thicker, etc., etc.
Old Jan 21, 2008 | 12:19 AM
jrose7004's Avatar
jrose7004
If mine drop that much the flat tire warning shows up on the DIC.
Old Jan 21, 2008 | 12:30 AM
Very good reminder.
Old Jan 21, 2008 | 12:39 AM
vettelover84's Avatar
vettelover84
Never Hurts to check!!
To Cold weather reminder
