Installed Blackwing today.
Old Jan 19, 2008 | 03:59 PM
VetteMonkey's Avatar
VetteMonkey
Default Installed Blackwing today.
Looks great. Installation was easy. Too bad it's snowing here today and can't get out to try it. Thanks to forum member HummelS for a great deal and transaction. I also installed a hood seal (after I took the pictures.)
Old Jan 19, 2008 | 04:04 PM
Lord Vetter's Avatar
Lord Vetter
St. Jude Donor '09-'10-'11-'12-'13
Don't forget to do the idle relearn.
Old Jan 19, 2008 | 04:06 PM
VetteMonkey
What!? I thought you just drive it and it learns the difference and resets itself... What do I need to do?
Old Jan 19, 2008 | 04:54 PM
csexton's Avatar
csexton
It will, don't worry about it
Chuck
Old Jan 19, 2008 | 05:10 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
I installed mine and five minutes later was at WOT trying it out.
Old Jan 19, 2008 | 05:23 PM
moserbe's Avatar
moserbe
Great job, looks good.
Old Jan 19, 2008 | 05:34 PM
Lord Vetter
Here's one I have that I have successfully used:
The car will re-learn simply by driving it between 50-100 miles. Or, the actual way to do it more quickly, is the following procedure:
1) Insert key into ignition and turn to the “ON” position, but, DO NOT START THE ENGINE.
2) Open the engine compartment fuse box cover and remove the two 10 amp fuses from position numbers 16 & 23.
a) According to the manual there are two fuse boxes. Use the engine compartment fuse block for this procedure not the instrument panel fuse block.
b) Engine Compartment Fuse Block (correct one): 16 is Powertrain Control Module A and 23 is Powertrain Control Module B.
c) Instrument panel fuse block (wrong one): 16 is Air Bag, 22 is Body Control Module-Ignition and 23 is Body Control Module-Ignition 2.
NOTE: Your DIC will now display “check” messages for ABS, etc… Do not worry as this is normal.
3) Turn the ignition key to the “OFF” position.
4) Return to the engine compartment fuse box and re-insert both 10 amp fuses for positions 16 & 23.
5a) Idle relearn for an M6:
1) Start the engine and allow the coolant temp to reach a minimum of 176 degrees F. Allow the engine to run at this minimum temperature for at least 5 minutes.
2) After the 176 degree, 5 minute minimum run, shut down the engine for a minimum of 30 seconds.
3) Restart the engine and check for DIC error codes (there should be none).
5b) Idle relearn for an A4: (different)
2) Allow the car to idle in DRIVE, with air ON and then OFF, for 5 minutes each, and then in NEUTRAL, with air ON and then OFF, for 5 minutes each.
3) Turn the car off for at least 30 seconds.
4) Restart the engine and check for DIC error codes (there should be none).
6) Drive car for a minimum of 30 miles at varying rpm settings and speeds. PCM will now re-learn and adjust for the new air flow and temperature at the intake.
a) If error codes persist, repeat steps 1-7. Make sure fuses are properly inserted before repeating steps.
b) Do not deviate from the sequence outlined above. If you do, restart the sequence from scratch.
c) Steps 1-4 are also necessary if you ever disconnect your battery or lose power for any reason.
Old Jan 19, 2008 | 05:58 PM
Johnny Hardcore's Avatar
Johnny Hardcore
The car will relearn the idle on it's own. You don't have to engage in the 10 step sillyness some are claiming you need to. The first drive in the car and it will automatically adjust itself.
Old Jan 19, 2008 | 08:03 PM
Timbrr's Avatar
Timbrr
Default Battery Question
Are you saying anytime you disconnect the battery (just to clean the terminals for example) those (4) steps must be followed. I have to admit this is the 1st time I have heard of this.
Old Jan 19, 2008 | 09:28 PM
LEANDRO's Avatar
LEANDRO
let the modfest begin
Old Jan 19, 2008 | 11:44 PM
Good choice in filters. I've had a Blackwing on mine for about 6 years and really like it.
Old Jan 19, 2008 | 11:51 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice mod and the hood seal is worth more hp gain than the good looking Blackwing you installed
Old Jan 20, 2008 | 12:44 AM
jrose7004's Avatar
jrose7004
Mine learned by itself.
Old Jan 20, 2008 | 12:47 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
We have smart cars!
Old Jan 20, 2008 | 09:30 AM
TomZ's Avatar
TomZ
I installed mine last year but then noticed pinging at WOT, so I put the OEM filter back on and the problem went away. Too bad since it looked so cool...
Old Jan 20, 2008 | 10:00 AM
VetteMonkey
I've done a bit of research regarding the "relearn" and the consensus seems to be... drive it, if there's a problem with idle afterwards, then perform the relearn procedure. Thanks guys for all the input!
Old Jan 20, 2008 | 10:05 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Look clean, great installation!
To Installed Blackwing today.
Old Jan 20, 2008 | 08:35 PM
VetteMonkey
Drove it and had no problems today. Idle was OK. The throttle response seems to be much better. I saw triple digits on the HUD faster than ever! It may be because it's only 32 degrees today but either way, I'm very satisfied with the Blackwing mod!
Old Jan 20, 2008 | 08:36 PM
Bob CTS's Avatar
Bob CTS
Very nice looking.
Old Jan 20, 2008 | 08:52 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
That was one of my first mods.
