'Nother foglight question.
Old Jan 20, 2008 | 04:36 PM
Dominic Toretto's Avatar
Dominic Toretto
Default 'Nother foglight question.
For some reason I am JUST NOW noticing this . My passenger side foglight is set further inside the bumper than the driver side one. Getting less light to the ground, can't really tell if your in front of the car. So I'm not sure how to adjust that. The driver side one is perfectly aligned with the housing while the passenger side one is sunk back in there. Please help me get this straightened up corvetteforums!
-Alex
Old Jan 20, 2008 | 06:24 PM
Big Als01's Avatar
Big Als01
I've had mine out before. Its been a while thou. If I remmeber right. From under the hood you can see the fog light bracket and the bolt that holds it in place. I think there is a tab at the bottom of the bracket that fits in a hole to keep it lined up right. You might check that the metal tab is in the hole. This would make it set back further. I hope this helps.
Allen
Old Jan 20, 2008 | 07:20 PM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
Yep, that's about the only way they would be off. Then put in the better bulbs, aim them up a little and they actually do something.
Bruce
Old Jan 20, 2008 | 07:32 PM
Dominic Toretto
Thanks guys I'll check it out tomorrow during the light.
Old Feb 17, 2008 | 09:23 PM
Dominic Toretto
Okay I'm really dumb, I must not be noticing which tab you guys are talking about . Can someone be so kind as to take a quick pic of this tab and how to adjust it?
-Alex
Old Feb 19, 2008 | 11:42 PM
Dominic Toretto
Bump.
-Alex
Old Feb 20, 2008 | 12:00 AM
Politronics's Avatar
Politronics
Check out this thread:
http://forums.corvetteforum.com/show....php?t=1687872
There are pics in there of the foglight mounts. Got little stars with arrows pointing to them.
JP
Old Feb 20, 2008 | 10:56 AM
Dominic Toretto
JP
Thanks bro.
To 'Nother foglight question.
