[Z06] first Z'S in C5
LS6 engine produces 405 HP in '02+ models.
Screened air inlets in the center of the front fascia that deliver additional cool air to the intake system.
Air scoop inlets on the sides of the front fascia that funnel air to the front brakes for better cooling. These inlets replaced the fog lamp housings and/or associated trim panels of the C5.
Air scoops on the rear rocker panels that funnel air to the rear brakes for better cooling. Z06 rear brake temperatures are reduced by as much as 10% under competition conditions; brake fade and wear are also greatly reduced.
Flat underside body panels for superior aerodynamics.
More effective front and rear brakes with distinctive red calipers.
The Z06 has the M12 6-speed manual transmission. It looks similar to the base-model MM6 manual transmission, however the M12 transmission is unique to the Z06, and is the only transmission available for that model; it is not available on Corvette coupés or convertibles.
The M12 has more aggressive gearing to increase torque multiplication in most forward gears, allowing for more rapid acceleration and more usable torque at higher speeds.
A special suspension (the FE4) was developed exclusively for the Z06, and is not available on other Corvette models. It features unique shock calibrations, a larger front stabilizer bar, a stiffer rear leaf spring, and revised camber settings — all calibrated with a bias toward maximum control during high-speed operation.
Also unique to the C5 Z06 are wider and lighter wheel rims and tires, which increase contact with the road and are essential to providing better grip.
Exhaust - The 26-pound titanium muffler and tailpipe assembly of the Z06 replaces the 44-pound stainless steel system used in the C5.
Misc - Thinner glass, reduced sound-proofing, fixed rear radio antenna, lighter battery, Z06 badges and emblems on exterior/interior.
Full article: http://en.wikipedia.org/wiki/Chevrolet_Corvette_C5_Z06
