[Z06] What H P gain??
Old Nov 30, 2001 | 01:45 AM
ZO6LS6's Avatar
ZO6LS6
Default What H P gain??
Shorty's, v.s. LT's??????????
I want to keep the pups, and wonder what the loss will be between the two........Shorty's should bolt directly to the pups.......LT's will not......
Anyone have a CLOSE estimate of the difference??. :confused:
[Modified by ZO6LS6, 5:46 AM 11/30/2001]
Old Nov 30, 2001 | 10:05 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: What H P gain?? (ZO6LS6)
38 Views..........and NOT one person that can tell me?????????
I would have figured a Vendor could, if not a gearhead!!!!!!!. :confused: :D
Old Nov 30, 2001 | 10:40 PM
rfgoss1's Avatar
rfgoss1
Lose the pups. You should still pass the sniffer and I believe you will pick up some HP.
Rg :cheers:
Old Nov 30, 2001 | 10:52 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: What H P gain?? (rfgoss1)
Randy, yes I think so also......BUT, won't pass a visual............... :rolleyes:
Old Nov 30, 2001 | 11:33 PM
Power Shifter's Avatar
Power Shifter
You need to talk to RAT, he has the shortys with the pups, and then he guted them so it would still pass visual. Ric
Old Nov 30, 2001 | 11:43 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: What H P gain?? (Power Shifter)
PS, already have, but he didn't dyno with JUST the shortys.......and then more added mods....he is kicking serious ponies with his rig.........
I am just trying to see IF the addition of the shorty's is WORTH the expense.....I have no intentions of CUTTING on my rig..........
So, if I want headers, these will have to be the ones.........RAT thinks the LT's are good for an EXTRA 5/10 over the Shorty's.........but, so far....no one has told me the BASIC gain with just the Shorty's.......v.s. Stock manifolds......
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
You will pass the visual, the cats will still be there.
Old Nov 30, 2001 | 11:57 PM
Power Shifter
The WORTH of these mods is in the eye of the beholder, that said the 10+hp you will get if you gut the pups also will be worth .1+ on the track if your driveing can take advantage of the gain. IMHO Ric
Old Dec 1, 2001 | 01:16 AM
BlueZ's Avatar
BlueZ
I am guessing, but I would think you will loose 5+ hp leaving the cats on from what you will gain with the shorty's. What's the diff. 02's don't have pups. :crazy:
Old Dec 1, 2001 | 02:40 PM
kentck's Avatar
kentck
How is the sound affected by the loss of the pups alone.
Old Dec 1, 2001 | 06:47 PM
6speeding's Avatar
6speeding
I used the bb shorties and noticed a good gain, seams like an honost 8 to 10 rwhp as I was promised by B and B . It was the most gain of any bolt on except air box of course. The l think the long tubes give about another 5 on top and probably double the gain in the midrange on a stock car. How ever if you do heads and cam the difference will be greater. Matt :yesnod:
To What H P gain??
