Replacement Head Lamp Bulbs
Old Jan 21, 2008 | 05:31 AM
vetter79's Avatar
vetter79
Default Replacement Head Lamp Bulbs
Anybody have any experience using the (new style I think) Sylvania Headlamp: Silverstar Ultra Halogen bulbs? (Part # 9005SU for High Beam, 9006SU for low beam)
If so, notice much difference in light output and quality compared to the OEM units?
Thanks in advance guys!
They're not the cheapest lamps but might be worth it if there's a noticeable output improvement!
Old Jan 21, 2008 | 05:41 AM
bobzap's Avatar
bobzap
Old Jan 21, 2008 | 07:40 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have used them for years, They are better over stock for sure, Are there better bulbs than Ultras...Yes. I like my Ultras.
Old Jan 21, 2008 | 08:33 AM
Pres712's Avatar
Pres712
Default Yes
I installed them over 2 years ago and they are better than stock. A hint....install all four with hi-beams. You will need to "Dremel" the little stub inside the socket of the bulb to fit the low beams but only takes a few seconds and you will have better light when on low-beams!
Old Jan 21, 2008 | 09:25 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
They are better than stock
But they are still pathetic
Go with the HID bulbs and you'll be able to see like you need to
Old Jan 21, 2008 | 11:25 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just change the wattage, no need to dremel anything.
Old Jan 21, 2008 | 06:12 PM
jdmvette's Avatar
jdmvette
Night Owl for life
waste of money. get an HID kit.
Old Jan 21, 2008 | 06:47 PM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Old Jan 21, 2008 | 08:55 PM
jrprich's Avatar
jrprich
To Replacement Head Lamp Bulbs
