[Z06] Question about lowering my ZO6?
Old Jan 23, 2008 | 08:57 AM
AlwaysNBoost's Avatar
AlwaysNBoost
Default Question about lowering my ZO6?
Hi guys Im interested in lowering my 2003 ZO6 using the stock lowering bolts. I was wondering if any of you guys have done this and how the car drove and handled? Or any other suggestion on how I should lower my car. I just want to clean up the gap in the back and a little in the front to give it a cleaner look. Thanks alot
Old Jan 23, 2008 | 09:04 AM
Slow Z06's Avatar
Slow Z06
Mine is lowered on stock bolts, with the front bushings shaved off. The rear bushings were cut in half.
Old Jan 23, 2008 | 09:27 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Do a search on this topic and you will find waaaaaaaay more than you are willing to read on this subject
Figure I would add that if you search there are also quite a few threads with detailed photos on the procedure too.
Old Jan 23, 2008 | 12:32 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Deleted a few hijack and off topic posts.
Old Jan 23, 2008 | 12:46 PM
AlwaysInBoost's Avatar
AlwaysInBoost
by "a few" I assume you mean my single post. I don't see how that effects anything but w/e... Jeez, give some people a little power and it really goes to their head.
Old Jan 23, 2008 | 12:59 PM
AlwaysNBoost
Nice how does the car ride and how much is that lowered??
Old Jan 23, 2008 | 01:23 PM
Slow Z06's Avatar
Slow Z06
Car rides great, lowered about 1.5 to 2 inches. Mine is however a little more harsh than others because I have T1 bars.
Old Jan 24, 2008 | 10:14 AM
AlwaysNBoost
Alright kool nice to know i will be lowering the car nice week hopefully thanks alot.
Old Jan 24, 2008 | 12:46 PM
sothpaw2's Avatar
sothpaw2
I did an alignment with mine and it handles better. It was lowered all the way on stock bolts but then I had it re-adjusted back up about 1/4" or so because I couldn't get the floor jack under to jack it.
So consider maintaince issues with this change.
I don't have any trouble with curbs or speed bumps with this ride height.
Old Jan 24, 2008 | 01:43 PM
Solofast's Avatar
Solofast
The amount to lower and how to do it are covered in a number of posts in this forum and on the C5 tech forum as well as on the autocross and road racing forum. Suggest that you do a search on lowering in each of those forums and you will be able to get a better idea on what and how to do it...
Here is one of the more recent threads, although there are a bunch of them out there.
http://forums.corvetteforum.com/show....php?t=1912039
There is a right way to do it and a wrong way and it is easy to screw things up by lowering it too much and/or doing it the wrong way. Do it right and it will make your car handle better as well as look better. Do it wrong and you can end up with some weird handling....
Old Jan 24, 2008 | 03:07 PM
SFCA1968's Avatar
SFCA1968
mine scrapes my driveway when I pull out
totally freaks the neighbors
Old Jan 24, 2008 | 08:09 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
...or leave it down and drive up on some 2x6's and jack to your hearts delight...
Old Jan 25, 2008 | 08:20 AM
AlwaysNBoost
Thanks for all the info everyone. Im pretty new to all this I only have owned the car for about 2 months. I did a big from fully buit hondas to fully built DODGE SRT-4 and now to this. But I wont be lowering it myself Cartek will be doing all the work on the car. If you guys dont mind posting up some pics of your zo6 lowered?
Old Jan 25, 2008 | 08:25 AM
sothpaw2's Avatar
sothpaw2
Yes but that's very inconvenient compared to just sliding the jack under and being done with it. My garage floor where I do the work is concrete and so it would be interesting holding down the 2x6's so they won't move.
Now the car is lowered but I can jack there rear jack point up and then let it down. Once this is done, the springs stay up for a bit, and this allows me to put the jack under the front jack point so I can change a front wheel.
Old Jan 25, 2008 | 09:20 AM
Nithros's Avatar
Nithros
St. Jude Donor '09
I do it all the time. I cut an angle on one end to make it easier to drive up on.
Old Jan 25, 2008 | 12:20 PM
ZEEEEOOOOSIC's Avatar
ZEEEEOOOOSIC
To Question about lowering my ZO6?
