Headlight Adjuster Hole Plug
Old Jan 23, 2008 | 11:19 AM
borkg2006's Avatar
borkg2006
Default Headlight Adjuster Hole Plug
Does anyone have a source for the round, black Headlight Adjuster Hole Plugs for a C5? I successfully installed a new gear kit from Rodney Dickman but apparently forgot to tighten the plug and it is gone.
Old Jan 23, 2008 | 11:25 AM
Ghost Vette's Avatar
Ghost Vette
Sometimes they will fall out and end up down near the fog light in side the front clip. Maybe you can get a light and check there first. Good luck.
corvettebob1's Avatar
corvettebob1
GM p/n 10435410
Old Jan 23, 2008 | 11:26 AM
lil vette's Avatar
lil vette
stealership...amazing enough only $4.00 - $6.00, I bought one.
Couldn't believe they sold anything under $100.00
Old Jan 23, 2008 | 11:28 AM
Oldvetter's Avatar
Oldvetter
You need to fill out your profile with the year car you own.
Early year C5's plugs are no longer available from the dealer. You have to change out the headlight surrounds and get new plugs. They are not expensive. You can buy the later year plugs from the dealer.
Try some used vendors if you absolutely need old plugs, and then use some silicone sealer on them.
Old Jan 23, 2008 | 11:36 AM
bighank's Avatar
bighank
Default old plugs are Caplug 2 1/8" and they sand free samples
How I got a replacememt. Use some RTV on old or new style to keep them in. Take off the 3 screws when working on the headlight. BIGHANK
Old Jan 23, 2008 | 01:11 PM
Dave1998's Avatar
Dave1998
I tried bubble gum and it did not hold up
Old Jan 23, 2008 | 01:37 PM
Junkman2008's Avatar
Junkman2008
I read a TSB on this very issue this morning. I also remember a thread where guys were replacing these plugs only to have them blow off in a week. This was with the 97-99 models I believe.
No me on the other hand could never figure out how to get mine off until just a few days ago.
Old Jan 23, 2008 | 02:32 PM
f355bird's Avatar
f355bird
on the newer style did they improve them so they dont fall off as easy? If so i will buy me a pair so i dont have to worry about it anymore.
Old Jan 24, 2008 | 02:04 AM
Junkman2008
Yea, they big time improved it. Like I said, I couldn't figure out how to get mine off and it has instructions right on the thing. They stay on real good now.
Old Jan 24, 2008 | 05:45 AM
travelingypsye's Avatar
travelingypsye
easy fix for under $2.............ductape........
Old Jan 24, 2008 | 07:57 AM
OGC5's Avatar
OGC5
Default Duct Taoe?
For a custom fix I used Black Electrical tape. $1.50 at Lowes.
OGC5
Old Jan 24, 2008 | 09:07 AM
jrose7004's Avatar
jrose7004
Ecklers has them, but I got mine at the Dealer.
Old Jan 24, 2008 | 09:15 AM
Slow Z06's Avatar
Slow Z06
i have none. i replace but they seem to be gone in a few days
To Headlight Adjuster Hole Plug
