amsoil weight?
Old Jan 24, 2008 | 04:27 PM
garrett3's Avatar
garrett3
8th Gear
Default amsoil weight?
Its my first car with a cam and didn't know if the cam made a diffrence in the weight oil I should use. So my ? is whats the best Amsoil to use in the engine on a cammed 01 Z06 (ms4) that will only see spirited street driving in Tx. I use 6 quarts of 5w40 in the WS6 with the longer k&n filter, does anyone do this with there vette to make it a nice even # of quarts
Old Jan 24, 2008 | 10:35 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Garrett,
As for the filter, I personally would not recommend a longer filter on the Corvette. Given the filters location, a longer filter will stick below the oil pan and be susceptible to hitting something, potentially causing a loss of oil pressure.
My thoughts on which oil to use. The new API SM standards put fairly restrictive limits on the ZDDP anti-wear additives that can be used in 30 grade oils. For a car out of warranty, I would consider the AMSOIL Synthetic 5w40 European Motor Oil. Note that this oil does not meet the GM Standard 4718M, which the owners manual requires for the Corvette. This oil has a High Temp High Shear rating of 3.7. As a comparison, Mobil 1 has an HTHS rating of 3.09. AMSOIL SAE Synthetic High Performance 10w40 has an even higher HTHS at 4.3, but the 5w40 will flow better when cold and is thus probably a better choice for a daily driver. FYI, in my track driven Z06, I use 10w40, but let the oil warm up to over 150F before I go out on the track.
If you desire to use an oil suitable for GM Standard 4718M, AMSOIL makes these products in order of cost/quality:
AMSOIL Signature Series Synthetic 0w30
AMSOIL SAE Synthetic 5w30
AMSOIL XL Synthetic 5w30
All three of these have HTHS ratings of 3.2.
I use the previous version of the 0w30 in my 06 CTS-V (I stocked up before AMSOIL came out with the new Signature Series 0w30 this fall).
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 24, 2008 | 11:40 PM
427435's Avatar
427435
Garrett3,
Please note that Amsoil only "recommends" the oils above for use where GM4718M is specified. The oils may or may not actually meet the spec.
You can count on the Mobil 1 to MEET the spec because GM says it does.
Old Jan 26, 2008 | 08:09 AM
NEO1's Avatar
NEO1
You could also use Mobil 1 0w40 which is used in Indy.
http://www.mobil.com/USA-English/Lub...il_1_0W-40.asp
ht/hs 3.7
Tbn 11.4
pao/ester
Old Feb 4, 2008 | 08:42 PM
03aaron's Avatar
03aaron
Mobile One Synthetic 10w 30...........That was i running in it before you bought the car....also whats the latest dyno #s you got?
Old Feb 5, 2008 | 05:32 PM
FOXMO's Avatar
FOXMO
C5 of Year Finalist (stock) 2019
St. Jude Donor '09
Mobil 1 is what the they run in the C5Rs and C6Rs at Le Mans. Why would you want to run something else???
To amsoil weight?
