What Size Tires
Old Jan 25, 2008 | 12:27 PM
SICK-VETTE's Avatar
SICK-VETTE
Default What Size Tires
Hey guys just would like to know what tires I should get and tire size???
Size: 19x8.5 front and 19x9.5 rear
Offsets: 38mm front and 45mm rear
Thanks guys
Joe
Old Jan 25, 2008 | 04:18 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Thanks guys
Joe
According to the charts that I referred to - the maximum size tire recommended for the width wheels that you listed are:
Front: P255-35x19
Rear: P285-35x19
With these sizes, you will not be running a tire that is either too narrow or too wide for the wheels. Also, these sizes will not cause any issues with your Traction Control or ABS. The front tire is an overall diameter of 26" and the rear is an overall diameter of 26.9". Also - the revolutions per mile - front=799 rear=744 (means the back tires are spinning slower than the fronts due to the taller tire) maintain the stagger that the systems are expecting to see.
I looked up the Michelin Pilot PS2, because that's the tire I run and recommend. It's a great non-runflat, and gives great dry and good wet traction. The single caveat is - it is not a winter tire. Hope that helps.
Old Jan 25, 2008 | 05:16 PM
edensknight's Avatar
edensknight
Excellent recommendation, Rands (Blacksedan87)! Moreover, the specific tire sizes Rands has suggested above in his helpful, and, very informative response also offers you a reasonable tire selection from which to choose from that includes, not only, Michelin PS2's, which, BTW, is an excellent tire choice, BUT, also Goodyear, Nitto, and, Falken, etc. tires. Unfortunately, there are certain tire size options that are more restrictive and limiting in tire brand-model availability. Luckily, for you, this is not the case. Good Luck to You!
Old Jan 25, 2008 | 05:52 PM
Russ K's Avatar
Russ K
Thanks guys
Joe
Those wheels will stick out ~20mm (.787") further than stock.
Russ Kemp
Old Jan 31, 2008 | 08:49 AM
SICK-VETTE's Avatar
SICK-VETTE
ttt
To What Size Tires
