Best oil filter for the C5?
#61
#62
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
AC Delco
#63
http://forums.corvetteforum.com/c6-z...er-vs-z06.html
http://forums.corvetteforum.com/c6-c...d-pf-48-a.html
Wasn't sure if a C6 oil filter is compatible with the C5 and if anyone is running it. I have no doubt I'm over-analyzing something that will make very little difference in the grand scheme of things but what else am I going to do on the forum
#64
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Geez, this thread is 6 years old
#65
lmao I was searching and going thru this thread when I suddenly noticed the date jump lol
Well I will contribute by saying after alot of research, the PF46 can't be beat for the price and quality. BTW, the PF46E is a more compact version of the PF46 but suppose to be the same thing, although I noticed both are available in some places.
#67
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Fram is as bad as they get.
Years back a member ripped open his K&N at the gas station on the humps for the tank fills.
I run Wix or Napa gold.
Check out bobistheoilguy. com for all you'll ever need to know about oil and a comprehensive oil filter comparison
#69
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Oil Filters & Oil ?
This is the contested subject just behind automotive batteries. FWIW I used to use Mobil 1 & a Mobil-1 filter but I have left the flock and now use a Mobil-1 oil filter and Royal Purple 5W/30. Not saying anyone better than any other, but my LS1 running is quieter from my seat ?
#70
Wix manufactures the majority of the commercial oil filters to their specs. including cheaper plastic parts less filter element and so on.Wix uses top quality innards and more filter material.My engine builder cut open a wix and a fram and I was stunned at the difference--Wix for me,they don't cost any more,and usually less,truckers and a lot of fleet owners use them,they learned through experience....good enough for me!!
#71
I was sad to see my newly aquired c5 had a ... FRAM I changed to a PF46 and Pennzoil Platinum oil...
#72
That'll be the white K&N with the nut welded on the end...nearly ripped mine off too on a plastic speed hump. The black K&N filter without the nut is fine.
#75
Received 3,812 Likes
GM used AC Delco filter to run their longevity testing for the LS1 design. That is what I use
#77
the "E" stands for Ecore.... its a cheaper version of a standard metal core filter. the Ecore has a plastic element cage, compared to a metal one.
the PF 44 was replaced with a PF 46, which is what I use now.
#78
It seems Fram is not very well regarded in general, but its Ultra line is in a total different league compared to the rest of their lineup:
Check this out for more details.
Take a look at this video showing one of them after 10000 miles in a car:
- Metal endcaps
- Dual layer synthetic media
- Wire mesh reinforcement as a 3rd layer behind media
- Silicone anti-drainback valve
- Thicker canister
- 15000 miles with synthetic oils
- Made in the USA
