Best oil filter for the C5?
Old 06-22-2014, 11:49 AM
  #61
norcalace
norcalace's Avatar
Originally Posted by tommypenguin
Might be a dumb question but figured I would ask, forgive me I'm a newb. Can we use the ZR1 oil filter on a C5, ie UPF-48R?
You dug up a 6 year old thread to ask a question that's unrelated to the topic? You're forgiven. What year ZR1 would you be referring to?
Old 06-22-2014, 12:55 PM
  #62
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
AC Delco
Old 06-22-2014, 12:59 PM
  #63
tommypenguin
tommypenguin's Avatar
I've scoured the forum for answers and this thread was as close as I could get. I just purchased an 01 SC'd corvette and am planning on doing and oil change this week. I'm going to run LS30 oil and wanted to use the best oil filter available. I read the oil filter used in the current gen ZR1 is the best available filter in the following threads.
http://forums.corvetteforum.com/c6-z...er-vs-z06.html
http://forums.corvetteforum.com/c6-c...d-pf-48-a.html
Wasn't sure if a C6 oil filter is compatible with the C5 and if anyone is running it. I have no doubt I'm over-analyzing something that will make very little difference in the grand scheme of things but what else am I going to do on the forum
Old 06-22-2014, 01:59 PM
  #64
knewblewkorvette
Support Corvetteforum!
knewblewkorvette's Avatar
Received 2,706 Likes on 1,668 Posts
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Geez, this thread is 6 years old
Old 07-15-2014, 10:54 AM
  #65
vettefx76
vettefx76's Avatar
lmao I was searching and going thru this thread when I suddenly noticed the date jump lol
Well I will contribute by saying after alot of research, the PF46 can't be beat for the price and quality. BTW, the PF46E is a more compact version of the PF46 but suppose to be the same thing, although I noticed both are available in some places.
Old 07-15-2014, 01:13 PM
  #66
RCFC5
RCFC5's Avatar
Baldwin B3 here
Old 07-15-2014, 01:41 PM
  #67
Camjamsdad
Camjamsdad's Avatar
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Fram is as bad as they get.
Years back a member ripped open his K&N at the gas station on the humps for the tank fills.
I run Wix or Napa gold.
Check out bobistheoilguy. com for all you'll ever need to know about oil and a comprehensive oil filter comparison
Old 07-15-2014, 04:32 PM
  #68
Marine One
Marine One's Avatar
http://www.minimopar.net/oilfilters/
Old 07-15-2014, 06:06 PM
  #69
killain
killain's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Default Oil Filters & Oil ?
Originally Posted by tellefan
I use Mobil 1 filters. There are many folks that rave about Napa Gold Series oil filters. David
This is the contested subject just behind automotive batteries. FWIW I used to use Mobil 1 & a Mobil-1 filter but I have left the flock and now use a Mobil-1 oil filter and Royal Purple 5W/30. Not saying anyone better than any other, but my LS1 running is quieter from my seat ?
Old 07-15-2014, 07:41 PM
  #70
Z06ufgrad2002
Z06ufgrad2002's Avatar
Originally Posted by itzza427
Wix manufactures the majority of the commercial oil filters to their specs. including cheaper plastic parts less filter element and so on.Wix uses top quality innards and more filter material.My engine builder cut open a wix and a fram and I was stunned at the difference--Wix for me,they don't cost any more,and usually less,truckers and a lot of fleet owners use them,they learned through experience....good enough for me!!
I only use Wix these days. Lots of really good info out there on their products.
Old 07-16-2014, 04:07 AM
  #71
vettefx76
vettefx76's Avatar
I was sad to see my newly aquired c5 had a ... FRAM I changed to a PF46 and Pennzoil Platinum oil...
Old 07-16-2014, 10:52 AM
  #72
eldudereno
eldudereno's Avatar
That'll be the white K&N with the nut welded on the end...nearly ripped mine off too on a plastic speed hump. The black K&N filter without the nut is fine.
Old 07-16-2014, 11:48 AM
  #73
Cowboy26a
Cowboy26a's Avatar
The last PF46 I installed leaked where the edge is rolled over. Put a mobil 1 on and no leak.
Old 07-16-2014, 10:31 PM
  #74
torchredmadness
torchredmadness's Avatar
I use Delco.
Old 07-17-2014, 04:36 PM
  #75
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
GM used AC Delco filter to run their longevity testing for the LS1 design. That is what I use
Old 07-17-2014, 06:23 PM
  #76
killain
killain's Avatar
Oldtimer
Default I didn't know that ?
OK Bill, It a case of PF46 filters this weekend. What does a PF46E mean ? Thank you for the direction.
Old 07-17-2014, 07:16 PM
  #77
Evil-Twin
Evil-Twin's Avatar
When I left GM it was PF 44.
the "E" stands for Ecore.... its a cheaper version of a standard metal core filter. the Ecore has a plastic element cage, compared to a metal one.
the PF 44 was replaced with a PF 46, which is what I use now.
Old 07-17-2014, 09:13 PM
  #78
GCG
GCG's Avatar
Fram is as bad as they get...
Originally Posted by vettefx76
I was sad to see my newly aquired c5 had a ... FRAM ...
It seems Fram is not very well regarded in general, but its Ultra line is in a total different league compared to the rest of their lineup:
  • Metal endcaps
  • Dual layer synthetic media
  • Wire mesh reinforcement as a 3rd layer behind media
  • Silicone anti-drainback valve
  • Thicker canister
  • 15000 miles with synthetic oils
  • Made in the USA
Check this out for more details.
Take a look at this video showing one of them after 10000 miles in a car:
Quick Reply: Best oil filter for the C5?
