Less than smooth shifting
Old Jan 25, 2008 | 09:03 PM
mag red vette's Avatar
mag red vette
Default Less than smooth shifting
I've noticed lately that when I shift from 2nd the 3rd in my MN 6, it seems like there's a "catch" as it goes into 3rd about half the time, almost like the syncros are a problem. I've been running Amsoil ATF for a little less than 10,000 miles. I was wondering if Amsoil Syncromesh would help, or am I looking at bigger problems? Any suggestions?
Old Jan 25, 2008 | 11:05 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Always start with the shifter alignment procedure. Its easy and simple to do and can be done in like 15 minutes total.
Old Jan 26, 2008 | 12:38 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
What is the shifter alignment procedure? I am having the same prob but with 1st to 2nd.
Old Jan 26, 2008 | 01:23 AM
dgrant3830's Avatar
dgrant3830
I'm sure its posted in the forum several times, but essentially the quick version is pull the center console cover out, then open the shifter assembly. Inside you will see the rod that connects it to the transmission with a star bolt in it. On the front of it, you will find an alignment pin in the raised position. Put the shifter into neutral, then push the alignment pin down into the hole, all the way till it stops. At this time, your shifter is locked in place and should not move. Loosen the star bolt and you will probably see the rod move to its neutral position. Tighten the bolt again then pull the alignment pin back up into its storage position and put the car back together. Before you put it all the way together, you might want to start it up and try it out first while sitting still, then put it back together.
Old Jan 26, 2008 | 02:48 AM
vetterlatethannever's Avatar
vetterlatethannever
Bookmarking.
Old Jan 26, 2008 | 02:51 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
To Less than smooth shifting
