I have presented this question in tech..
Old Jan 27, 2008 | 06:39 AM
dadsturn's Avatar
dadsturn
St. Jude Donor '08-'09
Default I have presented this question in tech..
but I want to get as much feedback as possible. For those that
have gone to 4.10's, with 6 speeds, just intake and exhaust
mods. If you ever had to do it again, would you go with the 4.10's?
If yes or no, give me reasons.
Old Jan 27, 2008 | 06:45 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
That's a whole lot of gear.
Are you planning to live at a drag strip?
Old Jan 27, 2008 | 07:28 AM
kww's Avatar
kww
I think the 4:10's are a perfect match with the 6speed. Started with intake and exhaust-then headers.1:85 rockers, etc. Without a doubt the gears where the biggest bang for the buck. With the A4 I wouldn't go more than 3:42's but with the 6sd it's been a lot of fun plus checking gas milage before and after I went from getting around 25.6 to around 25.2mpg. ECS did all the work and I wouldn't hesitate to do it again-only I would start with the gears and then work my way up.
Old Jan 29, 2008 | 10:47 AM
Wop1's Avatar
Wop1
I had a set in my old C4 M6, and at the strip they were great fun. And hard on the driveline with drag radials. The increase in mechanical advantage is amazing. What I did experience was redlining before the end of the track (stock internal LT1, 5200 RPM top), forcing a shift into 5th. When I finally broke the Dana 44 diff case in half with a hard launch, I replaced them with 3:73s. I eliminated the 4-5 shift, no loss of ET, and a more streetable car. That said, a C6 diff case is more robust, less likely to break, so that's less of a concern. But output shafts, U joints, half shafts are at risk as you lower the ratio, based on what I've learned.
Daily driving with 4:10s means 1st is unnecessary, you can easily start out in 3rd, go to 5th, then 6th. 3:73s still give great accelaration, but are more flexible. You'll have to decide, but I'll never go so low again on a street car. And my C5 is an A4, so 3:73s would be lower than I would go, 3:42s more like it if I choose to change the 3:15s. The A4 allows for a cushion, too, and consistent shifing makes for better times.
Old Jan 29, 2008 | 11:11 AM
Cliff99C5hardtop's Avatar
Cliff99C5hardtop
4.10's are great as long as you never plan on going to a SC or Turbo then they become useless. I would say the best bang for the buck with a 6 speed car is 4.10's!!! Do it and don't look back.
Old Jan 29, 2008 | 11:20 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
410's will give you a nice seat of the pants feel and the car will pull like nuts... but just remember, think of the bigger picture... If you ever add a lot of power , like a supercharger or heads/cam with big HP..you will have major traction problems unless you drive with slicks
I ended up going with 390's and am glad I did as they work well with my current power level, I can spin the tires, but I do have some traction left. Also remember 410's are very hard on the driveline if you are doing hard launches either at the track or on the street.
Old Jan 29, 2008 | 12:37 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Also remember 410's are very hard on the driveline if you are doing hard launches either at the track or on the street.[/QUOTE]
Why exactly is this? Can't see the correlation.
Old Jan 29, 2008 | 05:41 PM
DngrZne's Avatar
DngrZne
Why exactly is this? Can't see the correlation.[/QUOTE]
Because of the gear reduction the car is accelerating quicker, and therefore placing a lot more strain on everything after the rear end, mainly the halfshafts.
Old Jan 29, 2008 | 05:51 PM
mechryn's Avatar
mechryn
Man. This is such a . 4.10s are great in a N/A m6. Expect to lose 2 mpg. Cuts a half sec off your quarter. Huge increase in seat of the pants. Great bang for the buck. Find someone local or at a car show who has them and go for a ride.
Old Jan 29, 2008 | 06:16 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Exhaust mods...just a cat back or headers too?
4:10's were to short for me...JMPO
3.90's are the perfect gear for a N/A Car, all the way up to heads and cam...
Peace
Chip
__________________
..................Click for
To I have presented this question in tech..
