Active Handling Warm Up ... at every start
Old Jan 27, 2008 | 10:48 AM
Brice's Avatar
Brice
Default Active Handling Warm Up ... at every start
Well, I've worked on my car with the light and the radio on.
So I've run out of battery.
I 've ran the car with the help of another car.
Since, every time when I start the car and drive 100 feet I've got the "Active Handling Warm Up". It's warming up in 3 miles ! and then the message disapear !
any idea?
I've got the code B0605 BCM Internal Memory Malfunction
Old Jan 27, 2008 | 11:22 AM
R Devil's Avatar
R Devil
I've never had it happen to me but I've seen several posts on the subject. Try a search and see what comes up.
Old Jan 27, 2008 | 04:04 PM
Brice's Avatar
Brice
the message displays when :
-The weather is too cold (that's not the case here in France)
(Or Bad IAT Sensor : mine is ok)
-The wheel are not centered when the car is starting
But :
INITIALIZATION - Under normal driving conditions the yaw rate and steering angle sensors will be centered and the AH system initializes within seconds after driving the vehicle forward. However, if for some reason, one or more sensors have not centered and the driver has exceeded 20 kph for a period of time, the PZM will command the DIC message displayed "Active Handling Warming Up", and a icon will be illuminated. This message can be acknowledged and erased from the display. When the centering conditions have been completed the next message "Warmup Complete" will be momentarily displayed, and the icon turned off. The system is functional. If the system never centers the "Service Active Handling" will be displayed.
Where is that sensor ?
Old Jan 27, 2008 | 04:07 PM
BoostIt?'s Avatar
BoostIt?
I believe there is a steering position sensor at the base of the steering column, right off of the firewall. From what I hear it isn't fun to replace, but mine is going as I get a fault every now and then from it.
Old Jan 27, 2008 | 04:12 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I have found over the years that if I ever park my C5 with the wheels turned, at next start up I will get the AH warming up message every time.
Old Jan 27, 2008 | 04:28 PM
Brice's Avatar
Brice
Some news:
I've reseted the error code.
Now I've got just one:
GM list :
B2805 - Steering Whl Controls HVAC Switch Circuit Malfunction
Corvette Code :
B2805 No Transmitters Programmed
WTH?
Old Jan 30, 2008 | 07:49 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Did you ever get this figured out?
To Active Handling Warm Up ... at every start
