[Z06] need some advice
LS1 custom grind 231 237 .589 .595 112 379.99 379.99T
CC7955-16 COMP 7.400" CHROME MOLY PUSHRODS 114.99 114.99T
PAC1218 PAC beehive valve springs LS1 .600" lift 149.99 149.99T
SLP100225 SLP Corvette 25% Underdrive Pulley 1997+ 224.96 224.96T
BELTS BELTS 43.00 43.00T
ARP234-2503 ARP LS1 BALANCER BOLT 26.24 26.24T
TB100 Port Stock Throttle body 129.99 129.99
SLP21110 DONALDSON BLACKWING INDUCTION C5 259.51 259.51T
SLP21111 SLP C5 BELLOWS KIT FOR 01-02 85MM MAF 17.96 17.96T
SLP23066 C5 High Flow Bellows 46.30 46.30T
RP10W30 ROYAL PURPLE SYNTHETIC OIL 7 6.99 48.93T
KN1007 K&N Performance Gold Oil Filter LS1 F-body/Corvette 9.99 9.99T
A/C RECHARGE A/C RECHARGE 50.00 50.00
Labor Installation 650.00 650.00
KOO6104 Kooks C5 headers 1 3/4", stainless steel, 01-04 Corvette 879.99 879.99T
KOO6106 Kooks X-pipe system w/offroads, stainless steel, for use with Kooks
headers
379.99 379.99T
NGKTR55 NGK Copper Spark plugs set of 8 15.99 15.99T
MSD32819 MSD LS1 Superconductor 8.5mm Wires 61.99 61.99T
GM12558573 GM LS1 HEADER GASKETS PAIR 24.99 24.99T
SS298 AIR INJECTION BLOCK OFF PLATES, PAIR 8.00 8.00T
Labor Installation 325.00 325.00
DynoT98 TECH : NOTE CHECK & CLEAN MAF / 02's
Dyno tune 98-02 LS1
GEARS
INJECTORS
T-STAT
CAM
REV LIMITER
EXHAUST
MAF>>>NO PORTING<<<<
450.00 450.00
Discount Labor Discount Labor/tune as package -380.00 -380.00
Discount Parts Parts Discount -40.00 -40.00
$4,109.92
Last edited by rmbtowing; Jan 28, 2008 at 08:28 PM. Reason: hit the post button on accident cause i can barley use this thing
