[Z06] LS6 CAT Locations
Old Jan 29, 2008 | 04:49 PM
palamesa's Avatar
palamesa
Default LS6 CAT Locations
This may seem like a dumb question but where are the catalytic converters located in relation to the exhaust manifolds on a stock LS6 Z06? I have a 2003 LS6 that I'm putting into my '76 Vette. I currently have a set of F-Body exhaust manifolds from a 2002 Z28 LS1 that has the CATS attached directly to the manifolds (as shown). I was thinking about going with stock Z06 manifolds instead of the F-Body units but I'm not sure how the CATS and O2 sensors were set up. Does anybody have a picture of a complete stock system?
YES...I have to pass the California smog test, otherwise, Hookers and sidepipes!......GP
Old Jan 29, 2008 | 06:20 PM
Last C5's Avatar
Last C5
The 01Z had pup cats in about the same location as your picture and slightly larger cats another 24" or so down the pipe. 02-04 Zs did away with the pup cats.
Old Jan 29, 2008 | 06:26 PM
hotwheels57's Avatar
hotwheels57
...'04 LS6...
http://i114.photobucket.com/albums/n...6-27-07014.jpg
Old Jan 29, 2008 | 06:56 PM
palamesa's Avatar
palamesa
Perfect. I can see the O2 sensor location in the pic too. Much farther apart then the F-Body set up. I'm pretty sure the F-Body set up will work in my application. I was just thinking that having the CATS up by the engine will be really HOT. Looks like I may switch to a '03 Z06 type configuration to get the CATS away from the engine compartment. I'll be in the Hot Seat instead.
Also....is 2-1/2" the stock pipe size?
To LS6 CAT Locations
