Codes check engine light came on
Old Feb 1, 2008 | 12:24 PM
kenrsr's Avatar
kenrsr
Default Codes check engine light came on
Check the codes there were 10 pcm and a 60 ipc code showing. Reset the codes and check engine light went off. Does anyone know what these codes means anything to worry about. thanks alot.
Old Feb 1, 2008 | 03:35 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
1. we need to know what the codes were
2. we need to know what year your vette is
3. did you write them down, or just clear them
4. check the link below, it will tell you what the codes mean
5. fill out your profile and we can help you out a little better
Good luck!
http://www.gearchatter.com/index.php...95e5740a74d10d
Old Feb 1, 2008 | 03:38 PM
hotwheels57's Avatar
hotwheels57
http://www.corvettedoctor.com/Code_Main.html
To Codes check engine light came on
