Handling
Old Feb 1, 2008 | 01:05 PM
garye904's Avatar
garye904
Default Handling
I recently purchased a 2002 Coupe W/63K miles. I have noticed at highway speed a yawl - car wants to drift or grab the road (concrete) left and right. When de-accelerating car moves left and right. Is this worn tires, look about 1/2 tread left? The car was upgraded with brake calipers and I have noticed a spacer on the front hub, could this be a cause of the issue? Good Year R/F air pressure between 30 - 35 lbs. Not sure where to take car for inspection, Help Jacksonville, Fl.
Old Feb 1, 2008 | 01:09 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If you have 1/2 thread on the tires they should be ok as long as they look even, You might check into the alinement, Mine is as smooth as a babys behind...lol
Old Feb 1, 2008 | 01:13 PM
FASST LN's Avatar
FASST LN
Most cars with wide front tires will do this. The runflats, so I've heard, make it even worse.
My car, as well as my previous SS Camaro, would follow the grooves in the pavement too. The wheel ruts on some interstates are pretty bad and I have to really focus to not let my car veer into another lane.
Supposedly, the lower your tread, then the worse this becomes.
Old Feb 1, 2008 | 01:15 PM
FINNZO6's Avatar
FINNZO6
Old Feb 1, 2008 | 01:35 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
All of the above. Check to see if you have the stock tires. Spacers should be for different rims i would guess. A lot of stock corvettes wear the tires on the inside bad. I would have an alignment or have it checked and ask them to check the play in the steering too. Cheaper than replacing the tires. I have seen tires that look great on the outside edge and are worn out on the inside.
Tire pressure should be 30lbs Cold.
Old Feb 1, 2008 | 01:44 PM
SebringSixSpeed's Avatar
SebringSixSpeed
The side to side movement on road grooves is called tramlining. Like a previous poster stated most cars with wide front tires do this. The Run Flats do make it worse. I switched to non RF's and my car rarely does this any more.
Old Feb 1, 2008 | 02:27 PM
Bluefire's Avatar
Bluefire
I dumped the runcraps and no more tramlining. I bought the GY GSD3's.
Old Feb 1, 2008 | 02:57 PM
garye904's Avatar
garye904
thank you, i will start my tire reseach -
Old Feb 1, 2008 | 03:03 PM
garye904's Avatar
garye904
thank you will start my tire search
Old Feb 1, 2008 | 03:47 PM
jovette's Avatar
jovette
I experienced the same conditions with the car tramming as it would go down the road, with my OEM, 20,000 mile 8 year old G/Y RF tires. I replaced them with new Michelin Pilot Sport A/S ZPs (run flat) tires and have no such problem any more. The new Michelins cured the problem, 100%.
Old Feb 1, 2008 | 04:37 PM
jon c's Avatar
jon c
welcome to the world of runflats starting to show wear....
Old Feb 1, 2008 | 04:43 PM
IAIA's Avatar
IAIA
No runflats on the Z06, but I still get tramlining on my Michelin PS2's. But, it's not bad, but it was better when they were new. I have 30,000 miles on mine, but still have at least 1/3 tread on the fronts (back were sequentially replaced for free due to punctures). I don't do many burnouts.
Old Feb 1, 2008 | 07:17 PM
NOWUCME's Avatar
NOWUCME
I would still check or get alignment and check ball joints etc. Especially if you get new tires.....cheep way to protect your tires.
Old Feb 1, 2008 | 07:44 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Old Feb 2, 2008 | 08:10 AM
9secondflat's Avatar
9secondflat
the car i bought was road raced and as a result the suspension was set up for the track...the former owner had a few degrees of negative camber set into the suspension..when the tires were a few pounds low on air (after it sat for 1 month and it was 10 degrees out) i took it for a ride...the car was all over the road... lesson check the alignment and air pressure..
Old Feb 2, 2008 | 09:23 AM
corvette Mark's Avatar
corvette Mark
I had problems with the back end of my car swishing around and very unstable at high speeds and it turned out I had a bad rear tie rod end with less than 20k on the car. Easy to check for that.
Old Feb 2, 2008 | 09:31 AM
C5 4 ME's Avatar
C5 4 ME
No tramling here
Old Feb 2, 2008 | 10:13 AM
Toms2001PewterC5's Avatar
Toms2001PewterC5
I had a similar issue with my 2001 C5 when I first bought it. A friend told me that the OEM runflats were the problem. So at 29000 mi. I replaced them with Goodyear F1 GS-D3 tires and it was like I got a new car. The tires were definatly my problem and the new Goodyears completly changed the handling of my car for the better. It now handles and responds like a true sports car.
Old Feb 2, 2008 | 10:58 AM
2000lambovette's Avatar
2000lambovette
Default Im going to try coilovers
I have added larger tires and it will do this sometimes. I have been looking in to pfadt coilovers. i have heard they can eliminate some of what we are getting.
To Handling
