double din finally installed
Old Feb 4, 2008 | 11:10 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
good stuff. You'll love that sub/amp combo.
Old Feb 4, 2008 | 11:23 AM
VET IT B's Avatar
VET IT B
Looks great. How did you do your benzil? It doesn't look like you moved the HVAC head unit down?
Was there enough room just removing the one plastic tee bat between the old radio and HVAC unit? Is this a double din? Thanks, Mark
Old Feb 4, 2008 | 11:58 AM
Jammer's Avatar
Jammer
Cruise-In I Veteran
Cruise-In II Veteran
Old Feb 4, 2008 | 12:07 PM
DRKMATTER's Avatar
DRKMATTER
St. Jude Donor '09-'10
How's the HU being held in place? Looks like you're exposing the otherwise hidden top plate of the A/C...I def. would like to see some extreme closeups of the top and bottom of the HU. Did you have to cut out any of the metal (brackets) behind the HU?
Looks good!
Old Feb 4, 2008 | 12:20 PM
statredud's Avatar
statredud
5th Gear
Do you have any pictures of the space behind the bezel before the install? I am getting ready to tackle putting my D3 and want to do the same type of install you did. Curious if I need to flip the radio plate over like in other posts.
Great looking set up ! Can't wait to get mine done now.
Old Feb 4, 2008 | 04:49 PM
rollinred's Avatar
rollinred
Looks good!
i just went home depot and bought the equipment to make my bracket i trimmed the bottom part of the bezel 3 forth down and it worked perfect. i don't have any close ups you can found other dd installs like mine that has pics behind the head unit
you will have to cut the metal bracket behind there and the bracket that i made held it in place hopes this helps i don't have close up pic sorry
Old Feb 4, 2008 | 05:20 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Install, I like the idea that there is no need to cut the bezel.
Old Feb 4, 2008 | 05:22 PM
EPMM 03 C5's Avatar
EPMM 03 C5
very nice!
eric
Old Feb 4, 2008 | 06:00 PM
VET IT B's Avatar
VET IT B
Anyone else tried this?
