Door Rattle Fix!!!
Old Feb 3, 2008 | 11:48 AM
joe3451's Avatar
joe3451
St. Jude Donor '09
Default Door Rattle Fix!!!
The Problem With The Window Rattling When You Close The Door And The Window Was Down Is There Is Supposed To Be A Felt Pad On The Front Of Both Pully wheels, The Reason I Didnt See It Was Because They Were Both Missing, I Removed The Pass. Door Panel Which Wasn't Rattling And Long And Behold There They Were. I Went To Ace Hardware And Bought Felt Pads For The Bottom Of Furniture And Stuck Them On using The Self Adhesive supplied And Problem Solved. I Usually Take Pictures And Post Them But Was Pressed For Time, This Is A Simple Fix When You Get The Door Panel Off The Pully's Are Right At The Top Of The Door And Can Be Easily Seen With The Window Down. Hope This Helps If Any QUESTIONS FEEL FREE TO PM ME AND I WILL BE MORE THAN HAPPY TO HELP. GOOD LUCK!
