[Z06] Z06 And Cali
My '02 passed with efi remap and a Breathless Vortex Rammer with the AIR tube stuffed along side the rad shroud. Worse case you have to put a stock box on to pass...
bob
The three part test or the IM240 is the chassis dyno added to the other two tests where they actually load the motor to check for oxides of nitrogen. This is usually no big deal unless the car has been tuned. If its its tuned it usually is leaned out a bit, that means higher cylinder temps, and that leads to higher NOx. It's a real pita. If you haven't messed with the tune. No worries, if you have, flash the stock one back in for the day. Hopefully this helps answer your question.
P.S. The DMV website will list which smog area you are in, and you only need the check once every two years. Also, if anyone gives you the "don't worry about smog, it's no biggee" line, don't listen. It can be easy if you are prepared, but I have had a car fail for being 1 degree off on it's timing setting, and had a friend fail for not having the rubber flap that folds down from the gas tank filler pipe on his old Blazer that keeps gas off the paint. It had nothing to do with smog but it was on the emissions list so when it wasn't there, it failed. Best to avoid gas stations and find a normal shop, not a smog only place, just a normal mechanic. They tend to be the most forgiving, the gas station guys are like people working at big chain stores, they really don't care what happens to you or your car. Get the pretest, you don't want to end up on the gross polluter list for any reason, it adds hassles you don't want. Plus the pretests are usually free at non gas station smog places.
The guys who have not had to smog a car in Kalifornia are not doing you any favors by saying don't sweat it.
If you fail & have to go to a "referee" it's major PITA. You may get some break for being military & not have to change your tags, but I know nothing about that.
Good Luck!
If there is a local Vette Club, drop in a meeting & talk to the guys.
Borla has CARB certified two of their exhaust systems ... Borla Part #17206 and #17214 (don't know if those are the Stingers) under EO D-276-12 .... you can look up and see if a part is certified by going here .....
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
As Jaxian points out, some stations are **** about the visual, others are more relaxed. The last smog check I went through, the tech told me after the visual that if the car ran "clean" he'd ignore my CAI .... but if it failed the smog, he would have to report the intake ... fortunately I passed easily as the engine is otherwise stock.
For ACCURATE information on fees, and military people assigned to Cali ... go here (includes a fee calculator) ...
http://www.dmv.ca.gov/vr/newvehicle.htm
Welcome to the granola state (If you get rid of all the fruits and nuts ... you're still left with a pile of flakes) .....
Oh and often to replace the hose, you need to drop the gas tank. Fun.
It is getting tougher every year.
It makes it easy for the CARB to ensure that some moron doesn't modify his intake (or anything else) in some way that affects the smog output .... by controlling modifications, the CARB doesn't have to write a million "exceptions" in the rules ... it is cut and dry .... NO MODS WITHOUT AN EO.
So if i put the stock air box back on i should be fine?
What is the job market in the Vandenberg area (wife).
