K/N filter and Vararam
Old Feb 5, 2008 | 02:33 AM
RedRckC5's Avatar
RedRckC5
Default K/N filter and Vararam
For those vararam veterans. I had mine for 9 months . When do I need to refresh the K/N filter? Do I just follow the instruction from the spray bottle? Any advice? Got a couple of days off and looking forward to working and detailing the vette.
Old Feb 5, 2008 | 12:13 PM
timemender's Avatar
timemender
Procedure is straightforward when cleaning a K&N.
Follow the instructions on the K&N cleaning kit. (Cleaner & oil kit)
Flush GENTLY from the backside when rinsing. Using high-pressure water or air will damage the filter element.
Old Feb 5, 2008 | 12:54 PM
moserbe's Avatar
moserbe
Old Feb 5, 2008 | 02:21 PM
hotwheels57's Avatar
hotwheels57
If you run out of the cleaning solution, you can use diluted SIMPLE GREEN.
I always run out of the cleaning solution before the oil, which is the way it should be...oil very sparingly to avoid contaminating the MAF.
Old Feb 5, 2008 | 03:16 PM
RedRckC5's Avatar
RedRckC5
Thanks! Going to do it after my dentist appoinment.
To K/N filter and Vararam
