rev limiter
Old Feb 5, 2008 | 07:48 PM
joels's Avatar
joels
Default rev limiter
Could someone tell the the factory set RPM for the rev limiter on a 2003 Z06? Is it safe or necesary to increase it? Thanks
Old Feb 5, 2008 | 08:28 PM
joels's Avatar
joels
anybody!
Old Feb 5, 2008 | 08:39 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
someone in the tech section may know?
Old Feb 5, 2008 | 08:45 PM
jss812's Avatar
jss812
You could always run 'er up and find out. I've hit it on occassion, looks to be about 6700.
As to whether its safe or necessary, there's not much that's truly necessary. As to whether its safe, I'm going to guess that it's pretty close to max that a stock engine should see. I would expect stuff like bent pushrods when you get too high.
Hey, try it out and let us know how it turns out!!!
(you realize I'm just kidding about some of this stuff, right?)
Old Feb 5, 2008 | 09:05 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Z06 rev limiter is 6600 rpm.
I would not advise upping it without better valve springs and pushrods. Without a cam/blower/turbo, there isn't much reason to do so...your power is falling off way before that point.
Old Feb 6, 2008 | 05:38 PM
No reason to do it on a stock powerplant.
Old Feb 6, 2008 | 05:41 PM
LEANDRO's Avatar
LEANDRO
Yah I would have to agree, whats the point if you are not making anymore power.
Old Feb 6, 2008 | 05:46 PM
regorih's Avatar
regorih
Know of a lot of guys spinning stock bottom ends LS1/LS6 engines to 7000rpms with no problems.
To rev limiter
