manual trans
Old Feb 6, 2008 | 09:52 AM
judson whitley's Avatar
judson whitley
Default manual trans
have 2003 6 speed just recently notice sometimes when shifting to 5th gear it seems like it is just floating and will have to down shift back to 4th or go to 6th, does not happen very often any ideas,
Old Feb 6, 2008 | 10:32 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Doesn't sound like the shifter is positively engaging 5th gear. Are you running the stock OEM shifter? How many miles are on the car? When was the last time the oil in the transaxle was changed - if ever? If so - what kind of oil was used? Does this situation occur only when the driveline is cold or does it happen all the time? Does it occur when the ambient temps are cold/hot/etc.?
Old Feb 6, 2008 | 12:15 PM
SavPrato's Avatar
SavPrato
Never had that problem with my 03 6 speed. Curious to know how it turns out.
Old Feb 7, 2008 | 08:43 AM
judson whitley
have 53000 miles on it just had the diff fluid change yesterday when it first started it was when the vehicle was cold and now when it is warm sometimes it has all orginal items on it, had the differential svc at a gm dealer yesterday
To manual trans
