[Z06] Weird transmission "ringing"
Old Feb 14, 2008 | 10:18 PM
jclarksnakes's Avatar
jclarksnakes
I already played with the springs on mine with no difference in the sound. Many people claim the jingle is caused by the H-pipe. Many report good results replacing it with an X-pipe. A few of those with the X-pipe complain of excessive exhaust popping on decel.
Jeff
Old Feb 16, 2008 | 04:06 AM
KamiLos's Avatar
KamiLos
I usually hear the ringing only when decelerating in gear or when shutting it off as the rpm's drop.. I havent had a chance to put the spring in but Ill give it a shot. The weird part is that when I shut the ignition off with the clutch pressed in, the noise isnt as loud. But then again, that might be a totally different issue..
