[Z06] ls7
Old Feb 6, 2008 | 11:43 PM
geterdone's Avatar
geterdone
Default ls7
Will a ls7 clutch hold up and last on my car. I have a 2003 z06 that I am looking to make around 460rwhp.
Old Feb 7, 2008 | 12:04 AM
Sherminator's Avatar
Sherminator
Unless you're brutal on drivetrains, yes it will. Stock C6 Z06's make that power to the wheels. That's my new clutch coming soon with the same power.
Old Feb 7, 2008 | 12:11 AM
geterdone's Avatar
geterdone
Thats what I was thinking, dont feel like spending over a thousand dollars on a highend clutch. Would rather spend on other parts.
Old Feb 7, 2008 | 08:35 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You may be getting to the marginal power level for the LS7 clutch, stock C6 Z06's make that power but there are quite a few owners not happy with the clutch. Its a great clutch for a bolt on or mild H/C set up..... I have one in my car and it performs flawlessly.
Honestly I think you will be ok as long as your not planning on beating the snot out of it at the track
Old Feb 7, 2008 | 09:12 AM
smellya's Avatar
smellya
Just picked my car up from the shop. I had them install that clutch in it. I like it so far. I have around the same hp as you. 464/429 we will see how it goes.
Old Feb 7, 2008 | 11:21 AM
FlyinNOE's Avatar
FlyinNOE
I'm making 587 to the wheels on the LS7 clutch and have been doing so for almost 50,000 miles. It holds up nicely but I'm not super hard on it either. I'd put another one in if I had to do it again.
Old Feb 7, 2008 | 11:57 AM
97 SC Cobra's Avatar
97 SC Cobra
If you're going to put a sticky tire on it I'd pass on the LS7. One thing I've learned with these cars is to buy more clutch than you need. They're a PITA to change so dropping an extra $500 now may just save you money or time on your back in the long run.
Old Feb 7, 2008 | 06:21 PM
zeevette's Avatar
zeevette
You don't need to spend a grand on a better clutch. The Centerforce would be a definite upgrade from the LS7, and it costs way less than a thou'.
Old Feb 7, 2008 | 10:21 PM
geterdone's Avatar
geterdone
Centerforce clutch?? I will have to look into that. Any other opinions before I pull the trigger. Oh yeah which centerforce clutch series are you mentioning.
Old Feb 7, 2008 | 11:16 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
I would not buy a Centerforce clutch. They are not a quality product.
Get the LS7 clutch.
If youre making 500+ rwhp then get a Textralia.
To ls7
