center air deflector
Old Feb 7, 2008 | 06:06 PM
tngerman1999's Avatar
tngerman1999
Default center air deflector
I am in the process of installing a missing center air deflector on my C5. When I looked under the front end I cant seem to see anything that the deflector bolts to. Any help would be appreciated.
Old Feb 7, 2008 | 06:48 PM
hotwheels57's Avatar
hotwheels57
See if this helps you...some of the images will enlarge. Goes w/o saying that you will need bolts...
http://eliteengineeringusa.com/Radia...structions.pdf
Old Feb 7, 2008 | 07:40 PM
tngerman1999
thanks, But it really doesnt help me! I have absolutely nothing to bolt the piece to. Only thing i see is a small medal bar that stretches from side to side. No holes to connect to. It seems like I have a piece missing.Unless the bolts connect to some kind of clip which wraps around this metal bar.
Old Feb 10, 2008 | 08:57 PM
Awsum98's Avatar
Awsum98
Default middle deflector
that piece is held on by 2 bolts one at each end of the piece then the middle just clips onto the 2 aluminum blocks that are there.
To center air deflector
