Foglight out
Old Feb 7, 2008 | 10:38 PM
kevin323's Avatar
kevin323
Default Foglight out
Just noticed one of the foglights dead on my 97. Anyone change the bulb on one. Didn't get the chance to get down below to see where the socket is and no help in the owners manual. thanks for any info!
Old Feb 7, 2008 | 11:06 PM
jdmvette's Avatar
jdmvette
Night Owl for life
raise headlights, remove bezel, reach down, rotate connector, release bulb, replace bulb, reverse.
Old Feb 7, 2008 | 11:31 PM
kevin323's Avatar
kevin323
Default Thanks!
I'm sure I'd have come up with that...after a few hours. Thanks for the tip.
Old Feb 7, 2008 | 11:41 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
You forgot "install HID's" while you're at it.
Old Feb 8, 2008 | 02:33 AM
Junkman2008's Avatar
Junkman2008
Old Feb 8, 2008 | 02:45 AM
jdmvette's Avatar
jdmvette
Night Owl for life
oh yeah....reinstall with HIDs.
Old Feb 8, 2008 | 08:07 AM
And if you can't get your arm in through the headlight bezel, go in from below. There is an access panel on the underside of the front fasica that if you remove it, you have clear access to all the bulbs/sockets.
Old Feb 8, 2008 | 08:23 AM
WvCorvette's Avatar
WvCorvette
Find a skinny arm, and go from the top....much easier.
Old Feb 8, 2008 | 08:55 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i could do a bulb swap in <5 minutes this way. if you have to jack up the car to unbolt the panel underneath the facia to do the job, it will probably take a lot longer.
Old Feb 8, 2008 | 09:01 AM
kevin323's Avatar
kevin323
Default I'll try the top
I'll try pulling the bezel first. If I don't post in a while you guys will know I am stuck. Thanks to all
Old Feb 8, 2008 | 09:42 AM
Junkman2008
Once you get done, fill out your profile.
Old Feb 8, 2008 | 10:17 AM
steve8's Avatar
steve8
I have been told the sylvania 899 is a much better bulb. You may want to consider replacing both with these. They are 50w and supposed to be much brighter/whiter. Not HID's, but less than $10/ea. I have not done mine yet, so I can't give you first hand advice.
Old Feb 8, 2008 | 11:50 AM
waupachino's Avatar
waupachino
The 899 is a 38w Bulb. If you want the 50w bulb it is 885 and a decent improvement over stock.
Old Feb 8, 2008 | 11:58 AM
steve8's Avatar
steve8
You are correct. Sorry for the wrong info earlier.
Old Feb 8, 2008 | 12:05 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Just a thought, check the bulb with a meter first. Both of mine went out at the same time, but it was the ground splice pack being the cause. Both have seperate wires to that splice pack at the top right frame rail.
Old Feb 8, 2008 | 12:09 PM
kevin323's Avatar
kevin323
Default There is light!
Went to dealer . They sold me a Delco 899 for $19.80. Must have been the kick me sign on my back. Anyhow went the bezel route with no problem ( once I realized acess would be much better with the hood open). It looks like the old one is a little brighter but hard to tell in daylight. Wish I had seen the posts about the sylvania bulbs before I headed to Chevy. Oh well live & learn Thanks guys and I'll fill out the profile
Old Feb 8, 2008 | 03:22 PM
Junkman2008
Never go to the stealer!
Auto Zone, Pep Boys, O'Riley's, Western Auto, even high azz NAPA! Anyone but the stealer!
Old Feb 8, 2008 | 05:05 PM
sneakelman's Avatar
sneakelman
Did they at least kiss ya first?
Sorry, couldn't resist that one.
To Foglight out
