4 Post Lifts ???
Old Feb 8, 2008 | 01:42 PM
Brute's Avatar
0Brute
Former Vendor
Default 4 Post Lifts ???
Save Your Back!
The new Rack-5 is made for the 4 post lift with the removable type of ramps.This ramp has a lip to bridge over the operating rods or cables that runs in front of the steel beam.
These are a light weight alternative to those HEAVY ( over 45lbs) hard to store ramps that came with your lift! Just think no more will you have to move those anchors around!! The rack ramps weigh only ten pounds each!! They even have a handy top side strap for easy placement.
________________________________________ ________________________________________ __
Rack ramps were designed for the auto enthusiasts or a service technician with a car rack/ 4 post lift to enable you to get troublesome low riding cars onto the rack without damaging the front end of the car.Rack ramps were designed for the auto enthusiasts or a service technician with a car rack/ 4 post lift to enable you to get troublesome low riding cars onto the rack without damaging the front end of the car.
Race Ramps Group Purchase
15% Discount - On all our Products.
Hurry!!! GP Ends Feb. 18, 2008
Enter Code cfcoup3
www.raceramps.com
Old Feb 8, 2008 | 04:08 PM
Brute's Avatar
0Brute
Former Vendor
Originally Posted by hotwheels57
I like both of the ideas. The BEND PAK ramps that are "permanently" attached on my four post HD9 are 36" long and heavy. They hinge down when the lift rises.
I was going to have someone build me some extensions to hinge off the steel ramps at approx. midpoint @ 18" and be 36" long. The total ramp length would be +/- 54".
Your RACK RAMP 4 would be +/- 62".
Are they also a plastic composition?
The product is a high density coated polystyrene with its ledge - which the steel ramp plate rests on - reinforced. Do you have a pic you could post of your ramps. Our product should be the best and easiest solution, but lets make sure modifications aren't required.
Thanks,
Bill
Old Feb 8, 2008 | 04:33 PM
hotwheels57's Avatar
hotwheels57
I deleted my post since I did some more reading on your site and answered the question about your ramps composition.
The steel ramps on my BEND PAK lift are 36" long x 18" wide and hinge off the crossmember. They each have two DELRIN rollers on the leading edge.
I made these pre-ramps from 3/4" plywood, which are stepped, 40" long by 24" wide x 2" high. The steel ramps come down on top of the plywood ramps so I don't need to reposition them each time.
http://i114.photobucket.com/albums/n...p011608006.jpg
Old Feb 8, 2008 | 04:55 PM
Brute's Avatar
0Brute
Former Vendor
It looks like those work for you!
Thanks for taking a look.
Old Feb 8, 2008 | 05:01 PM
hotwheels57
Your product might give more lift though, 4" maximum height vs 2".
My issue is that I leave my BMW lift pucks in place permanently. My car is only 5/8" lower than original, which is just enough to scrape on the rear pucks when driving on/off the lift.
I'll do some thinking about submitting plans for longer/wider ramps from your "custom ramps" link. Thanks!
Old Feb 8, 2008 | 05:08 PM
Patches's Avatar
Patches
This may be just what I'm looking for. Not only do I use 2x10's as extenders so I don't rub my rockers on the lift, I also don't enjoy lifting the stock ramps into place when I need them. Here's what mine looks like when I need to roll the Vettes on or off.
Old Feb 8, 2008 | 06:35 PM
Brute's Avatar
0Brute
Former Vendor
First of all, you win the clean & uncluttered garage award.
& Nice Red Ride.
As you can see our Rack-5 is 40" long with 5" under the extention lip so you would want to measure your lift height after removing the existing steel ramps and measure to see if it is 5" from floor surface to top of steel.
Hope this helps!
Old Feb 9, 2008 | 01:08 AM
Novat_99's Avatar
Novat_99
Hmmm...might be what I need to replace the wood extensions...those darn things are heavy.
As you can see, due to the pitch in my garage floor, I need quite a bit of help to get high enough to clear the front end (even with the factory 4 ft aluminum extensions in place).
Old Feb 9, 2008 | 10:02 AM
Brute's Avatar
0Brute
Former Vendor
You've answered the first request with all the helpful pics!
So, you want to replace the wood ramps only? Those metal ramps can't be light.
Or would you consider one ramp to replace the two pieces you currently use??
Your pictures would indicate the later.
Let us know, Brute
Old Feb 9, 2008 | 10:35 AM
Patches's Avatar
Patches
Pretty sure the RR-RACK-5 will work on my lift. My crossmember is 4" high total and less than 1" from the floor so 5" looks perfect. Only question is are they long enough so I don't have to use extender boards to clear my lowered vettes? The weight savings alone are worth it, I think.
Old Feb 9, 2008 | 11:40 AM
Brute's Avatar
0Brute
Former Vendor
The Rack-5 Ramp is 40" long with a 8 degree pitch. Use the guide below as a tool to determine if they will work.
Let us know before you order the height at the end of the yardstick. OK? Thanks, Brute
Old Feb 15, 2008 | 07:43 PM
Brute's Avatar
0Brute
Former Vendor
3 Days Remain Group Purchase!!!
Old Feb 17, 2008 | 09:54 PM
Brute's Avatar
0Brute
Former Vendor
Less than 27 Hours Remain for This GP!!!
www.raceramps.com
enter code cfcoup3 15% savings on all products
Think about it
Old Feb 18, 2008 | 11:20 AM
Brute's Avatar
0Brute
Former Vendor
12 Hours Remaining For GP!!!
Old Feb 18, 2008 | 02:18 PM
Novat_99's Avatar
Novat_99
Let us know, Brute
Bill,
I'm looking to replace the wooden extensions. The metal ramps that attach to the lift are actually made of aluminum and are very light...those wood ramps are a different story
I'll measure them tonight when I get home...I'm assuming the best approach would be the custom design option?
Tom
Old Feb 18, 2008 | 04:56 PM
Brute's Avatar
0Brute
Former Vendor
Originally Posted by Novat_99
Bill,
Tom
Tom, look at our trailer ramp section before measuring. One of those may work. Order tonight if possible the shopping cart stops accepting the code cfcoup3 at Midnight EST -15%
http://www.raceramps.com/store/shopexd.asp?id=73
Thanks,
Bizzzyyy Brute
To 4 Post Lifts ???
