Flat Tires with Non Run Flats
Old Feb 8, 2008 | 11:37 PM
MVetteNJ's Avatar
MVetteNJ
Default Flat Tires with Non Run Flats
I am about to throw out my Goodyear EMTS that were nothing but horrible steamroller noisey tires! I am going to go with Generals for about 500.00 for a ALL 4!
I was wondering if I were to get a flat tire I was told that the Fix A Flat spray (solution when stuck on the side of the road) can will destroy the tire pressure sensor mounted inside my tire? Is this true? Also anyone have a spare doughnut that they carry? I use to have a C4Vert and it had a spare!!!
Old Feb 8, 2008 | 11:44 PM
moserbe's Avatar
moserbe
Yes, your tire pressure sensors would be rendered useless. Some C5 owners carry a spare from a newer GTO.
Old Feb 8, 2008 | 11:45 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
No goop in the tires if at all possible. What I carry is a ZO6 tire kit, It has a pump and goop in the kit, What I did was add a plug kit to it, In most cases the plug will work, If it doesn't I have AAA.
Old Feb 8, 2008 | 11:49 PM
jrose7004's Avatar
jrose7004
I wouldn't put that stuff in there! Get a tire repair kit and a small compressor to plug into your cigarette lighter.
Old Feb 8, 2008 | 11:56 PM
wamara's Avatar
wamara
Cruise-In II Veteran
All true, but I suppose (at least for the '01+ cars), the sensors are cheap enough if you find yourself in a jam....
To Flat Tires with Non Run Flats
