Strictly Dyno sheets thread.
Old Feb 18, 2008 | 01:23 AM
hangpilot's Avatar
hangpilot
Vararam CIA, Ported TB, Maganaflow cat backs, tune.
Old Feb 18, 2008 | 01:52 AM
icyteddy's Avatar
icyteddy
[IMG][/IMG]
Here is mine. Mods are in signature.
Old Feb 18, 2008 | 03:54 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Mods are in my sig...
STD
SAE
Comparison of before and after the Tune;
Old Feb 18, 2008 | 01:25 PM
WickedQuik's Avatar
WickedQuik
Simple bolt ons added: 2003 Automatic - LG Headers, BPP CAI, Stock Ported TB, Corsa Pace Car, and Vengeance tune.
Old Feb 18, 2008 | 01:37 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Mine with the hood seal removed, when I installed the hood seal I got 749
Old Feb 18, 2008 | 02:00 PM
C5XTASY's Avatar
C5XTASY
Iwas wondering about those numbers you got with those mods until I noticed that the graph was converted to flywheel horsepower. Never saw that before on a dyno sheet. Do you know what loss correction factor they used? Thanks.
Ed
Old Feb 18, 2008 | 02:33 PM
tstar's Avatar
tstar
You're going to hell!
Old Feb 18, 2008 | 02:52 PM
Wickd1's Avatar
Wickd1
Tune, LS6 Intake,373,gears,Corsa catback,.Blackwing CAI...ARH Headers next week..
[IMG][/IMG]
Old Feb 18, 2008 | 03:09 PM
chriswtx's Avatar
chriswtx
Here's mine, lower red lines are with the Magnacharger, upper blue lines are with the ECS Paxton supercharger. Both on the stock motor with cam and headers..New forged bottom end numbers soon!!
Old Feb 18, 2008 | 03:11 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
It is true, I do have the other chart looks the same just a few more ponies, the real reason was changing from TPIS Headers to AR Headers
Old Feb 18, 2008 | 03:28 PM
lil vette's Avatar
lil vette
Default Can someone tell me if this is a good running motor
This was with magnaflow exhaust mod. 2002 coupe
What's with all the sqiggly at the end?
Old Feb 18, 2008 | 05:50 PM
TM-Z06's Avatar
TM-Z06
Ed
Those numbers are not converted flywheel from the engine - the Dynapak states "flywheel" because it's measured from the flywheel of the Dynapak. The Dynapak removes the wheels and measures actual torque from the axle, then uses the rear-end gears to convert to rwtq and rwhp.
Old Feb 18, 2008 | 05:56 PM
  #33
chriswtx's Avatar
chriswtx
The tuner had the smoothing set to 0..Next time make sure its set to 5, it will look alot better...
Old Feb 18, 2008 | 06:59 PM
  #34
C5XTASY's Avatar
C5XTASY
What is the value of that other than to give you a higher number? The numbers would be lower driving the actual wheels that are on the car. I don't understand. Please explain.
Ed
Old Feb 18, 2008 | 07:01 PM
  #35
C5XTASY's Avatar
C5XTASY
With the smoothing set to 5, also have him use SAE correction. The overall result will be lower numbers, but truer.
Ed
Old Feb 18, 2008 | 07:03 PM
  #36
aquaholic's Avatar
aquaholic
i think it would help this thread if everyone would list the year and model of their car with the mods when posting the dyno sheet
Old Feb 19, 2008 | 01:06 AM
  #37
miami993c297's Avatar
miami993c297
2002 ZO6, 346 Ci NA Stock Shortblock on pump gas, Daily Driver.
Mods in sig:
Christian
To Strictly Dyno sheets thread.
Old Feb 19, 2008 | 01:12 PM
  #38
TM-Z06's Avatar
TM-Z06
Ed
That's the thing.....you're looking at it from the "wrong" view point. These machines (Dynojet, Dyno-mite, Dynapak, etc....) are devices for tuning, each measuring and calculting hp & torque differently. The dynojet IS NOT necessarily the most standard or correct device for measuring hp/tq, it's just the most popular.
Old Feb 19, 2008 | 01:24 PM
  #39
Thickraybans's Avatar
Thickraybans
Graphs are here http://forums.corvetteforum.com/show...post1562962326 Mods in sig.
Old Feb 19, 2008 | 03:57 PM
  #40
C5XTASY's Avatar
C5XTASY
I do understand that that they are just tuning tools. I've had a few before and afters done on my car, also (see sig). I do know that the Dynojet and Mustang (which gives lower readings than the Dynojet) seem to be the most prevalent, and I do understand how both of those work. I had just never heard of the Dynapak before. Interesting.... What bothers me on dyno numbers being quoted car-to-car, is that it's rarely an "apples-to-apples" comparison, as dynos are different. Also, some tuners run SAE corrections, some Standard uncorrected, some change smoothing numbers, etc., all of which can fairly dramatically change power and torque ourput numbers, thereby making many of them meaningless for comparison purposes. As an example, I've seen really high output numbers quoted and then when you look at track times for those same cars, those dyno numbers seem bogus (and probably are). And, on the other hand, some quote relatively low numbers, but the car burns up the track. Too bad there'e not some overall standards or correction factors in place to standardize the numbers from different dyno manufacturers, or, tuners wouldn't play with the software to make their work appear better than it actually is.
Ed
