Caliper Replacement Cost?
Old Feb 12, 2008 | 05:49 PM
Safedog's Avatar
Safedog
Default Caliper Replacement Cost?
Just bought red calipers to replace my stock greyish colored ones. Was reading some threads on the topic and just don't feel competent to do myself.
How much should I expect to pay to have the local GM dealership to do this? Should I trust anyone else to do?
Thanks in advance!
Karl
Old Feb 12, 2008 | 06:23 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks in advance!
Karl
It's an easy job. You could do it yourself in a few hours.
Old Feb 12, 2008 | 06:25 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Don't go to the stealership,you'll get raped.
I'm sure there are plenty of competent shops in NY
that will do this for you at a "fair" price.
Try asking this question in the regional forum,
I'm sure someone in your area can recommend
some choices.
Just my $.02 worth.
Good Luck!!!
Old Feb 12, 2008 | 06:27 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
some choices.
Just my $.02 worth.
Good Luck!!!
I have my local speed shop "Speed Inc" do just about anything, there parts or mine.
Old Feb 12, 2008 | 06:30 PM
Safedog's Avatar
Safedog
Still looking for some ideas of cost. If there is a detailed, photo-based DYI...could someone please forward to me?
Thanks again....
Karl
Old Feb 12, 2008 | 06:31 PM
Safedog's Avatar
Safedog
...also, being in extreme upstate, NY....I am "geographically' challenged with car shops....that those of you in bigger cities have choice.
Old Feb 12, 2008 | 06:32 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Not to make you feel bad.....but if it's not too late, send your red calipers back and just paint the ones you have. The only difference between what you bought and what you already have is the color.
Heck - you don't even have to take them off to paint them.
My guess, about 3 hours labor at a dealership. They will have to bleed the brakes when they make the switch.
Old Feb 12, 2008 | 06:33 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Which is about $300.
Old Feb 12, 2008 | 06:35 PM
Safedog's Avatar
Safedog
Default Too late....
....they're on the way.
Old Feb 12, 2008 | 10:12 PM
bugsas99's Avatar
bugsas99
don't open package and send back. don't see why you wouldn't get a refund if package is unopened.
Old Feb 13, 2008 | 12:21 AM
damilleniumboy's Avatar
damilleniumboy
Old Feb 13, 2008 | 01:37 AM
Bill Dearborn's Avatar
Bill Dearborn
Thanks again....
Karl
Karl,
Send me a PM with your e-mail address and I will send you a copy of the brake caliper R&R section of the Service Manual. Biggest problem you will have is getting the car into the air so you can work on it. If you don't have a heated garage you may want to wait about 4 weeks before attempting this.
Bill
Old Feb 13, 2008 | 06:48 AM
Wildcat99's Avatar
Wildcat99
One of our club members just had his replaced at a local dealer. Paid 225$. The hardest part is breaking the caliper bolt loose, but with the right tools, not that bad. Anything over 175$, in my opinion, is to much. Try doing a serch about caliper removal on here. If you don't come up with anything and want to try it yourself, there are many on here who will help walk you through it. I changed mine out in less than 2 hours, and was going to help change out my friends but he couldn't wait until the weather warmed up some. I hope this helps.
http://forums.corvetteforum.com/show...aliper+removal
Old Feb 13, 2008 | 09:43 AM
Phanni's Avatar
Phanni
I just finished changing my calipers, rotars and pads.
The biggest problem was removing the caliper holding bolts on the lower rear caliper. I couldn't get my air impact wrench on it so I needed a breaker bar set up to break loose the red lock tight and 150 ft.lbs. of torque the factory puts on these. I took about three hours (I'm not a real mechanic, but I stayed at a Holiday Inn once).
I'd think a good brake shop should do this for you for 2 or three hours labor.
Old Feb 13, 2008 | 10:09 AM
TrplBlk01's Avatar
TrplBlk01
Thanks in advance!
Karl
I felt the same way. To my surprise it was fairly easy to do.
To Caliper Replacement Cost?
