Bad idea. I bought my 04 new and had to sign a document indicating that I would not install any type of snow chains on the car or the warranty is null and void.
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Originally Posted by Storm Cloud
I am going to get flack for this.
Ya think? If you do, make sure you get the ones with the welded on V bars. I wonder if you could use them at the drags in summer? Good dig off the line. Maybe www.tirechains.com will become a CF supporting vendor.
Notice:
Don’t use tire chains. They can damage your
vehicle because there’s not enough clearance.
Use another type of traction device only if its
manufacturer recommends it for use on your
vehicle and tire size combination and road
conditions. Follow that manufacturer’s
instructions. To help avoid damage to your
vehicle, drive slowly, readjust or remove the
device if it’s contacting your vehicle, and don’t
spin your wheels.
If you do find traction devices that will fit, install
them on the rear tires.
