Spedo Recalibration???
So what am I to do... Will a Predator handheld allow me to get things reading correctly? Or can I just live with this and always wonder just how fast/slow I'm going?
Here's the Predator parameter list.
- Timing Table 1000-1800rpm (+/- 20%)
- Timing Table 2000-4000rpm (+/- 20%)
- Timing Table 4000-7000rpm (+/- 20%)
- Fuel Table 2000-4000rpm (+/- 20%)
- Fuel Table 4000-7000rpm (+/- 20%)
- Idle (+ 500rpm / -300rpm)
- Speed Limiters (Trucks Only)
- Rev Limiters
- RPM Shift Points
- MPH Up and Downshifts
- Shift Timing
- Shift Pressure
- Cooling Fan ON and OFF temperatures
- Re-Calibrate Speedometer for Gear and Tire Size Changes
- Torque Management abuse mode time limit ON/OFF
- % torque reduction vs. RPM ON/OFF
- Upshift torque reduction (all gears) ON/OFF
- Adjust for different injector size
- Disable P0420 and P0430 codes
- Adjust COT enable temperature
- Misfire Low rev
- Misfire Low cyl
- Misfire idle cyl
- Enable/disable MPH, set high to disable
- Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
- Disable P-codes: 0410, 0412 and 0418
- Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
- All standard DiabloSport Predator features
What brand of tires are you looking at?
Russ Kemp
FRONT
Stock tire new tire
245/45-17 255/35-18
sidewall 4.3 in 3.5 in
radius 12.8 in 12.5 in
diameter 25.7 in 25.0 in
circumverence 80.7 in 78.6 in
rev/mile 785.0 806.0
REAR
275/40-18 285/35-19
sidewall 4.3 in 3.9 in
radius 13.3 in 13.4 in
diameter 26.7 in 26.9 in
circumference 83.8 in 84.4 in
rev/mile 756.0 751.0
