Window Valet Question
Old Feb 14, 2008 | 11:49 AM
SLWRNU's Avatar
SLWRNU
Default Window Valet Question
Recently when I activate the window up feature there seems to be too much pressure on the driver's side window and about half way up it must detect the resistance and will reverse both windows and go back down. If I "help" it up it's fine but obviously this defeats the purpose of the Valet.
Anyone run into this issue before?
Old Feb 14, 2008 | 11:52 AM
02MillenniumVette's Avatar
02MillenniumVette
Does that happen everytime you try to activate the windows up? Ive had it happen a few times but it doesnt happen a lot.
Old Feb 14, 2008 | 11:53 AM
hotwheels57's Avatar
hotwheels57
Did you contact the manufacturer?
http://www.topdowntech.com/about.html
Old Feb 14, 2008 | 12:02 PM
SLWRNU's Avatar
SLWRNU
All fine up to a few months ago. Now it happens every time. Had a battery go down and thought maybe that was the problem but put a new Red Top in and still does it.
Almost seems like the door panel seal is impeding the up.
Old Feb 14, 2008 | 12:52 PM
rcarl's Avatar
rcarl
try recalibrating.
if you don't have instructions, they are here:
http://www.topdowntech.com/documents/WV-100.pdf
Old Mar 1, 2008 | 08:55 PM
Tannman's Avatar
Tannman
I would re-calibrate and, if necessary, set the window up strength to "strong."
To Window Valet Question
