Change your clutch Fluid
Old Feb 16, 2008 | 05:17 PM
NicksZ06's Avatar
NicksZ06
Default Change your clutch Fluid
WOW!! I just changed mine following Ranger's suggestions and boy what a difference. I dont think it had ever been changed. It's smooth as butter and shifts are much much faster. Almost like a new car. My Z06 has 42k on her what other fluids should I change soon?
Link to Rangers page. http://www.rangeracceleration.com/Clutch_Care.html
Old Feb 16, 2008 | 05:44 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
What fluids to change? All of them, yearly.
Old Feb 16, 2008 | 06:01 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Gonna change mine next week!
Old Feb 16, 2008 | 06:03 PM
NicksZ06's Avatar
NicksZ06
Yearly? Any instructions to changing manual tranny fluid or rear end fluids.
Old Feb 16, 2008 | 06:39 PM
2fast4sanity's Avatar
2fast4sanity
I tried to change out my clutch fluid a while back. Pumping the clutch didn't do anything to mix up the fluid. After driving for 5-10 minutes after I thought I had made progress, it was dark again Is there a trick to this or is my fluid just that bad?
Old Feb 16, 2008 | 06:43 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I felt as though my shifting was smoother after a fluid change too!
Old Feb 16, 2008 | 06:54 PM
NicksZ06's Avatar
NicksZ06
Did you replace the cap snugly every time? IT took be about an hour to do this but i pumped 20-30 times for about 15 refills
Old Feb 16, 2008 | 07:06 PM
hotwheels57's Avatar
hotwheels57
Mine was turning an amber color @ 5,600 miles, but I didn't want to wait until it turned black. I used Ranger's method to remove the old fluid and used regular Dot 3 brake fluid for the cleansing procedure.
I changed it maybe three times and pumped about 30 times in between. It stayed clear. I removed it one more time and filled with synthetic fluid for the final time. After 500+ miles, it's still clear.
Old Feb 16, 2008 | 07:18 PM
NicksZ06's Avatar
NicksZ06
MINE was completely black!
Old Feb 16, 2008 | 07:29 PM
2fast4sanity
I tried with the cap on and off. I went through 2 bottles of DOT4 and it was still dark, just not as dark.
Old Feb 16, 2008 | 07:32 PM
Red99FRC's Avatar
Red99FRC
You just gotta keep on changing it over and over, and eventually you'll get to where it stays clear!!
Old Feb 16, 2008 | 08:38 PM
Bob CTS's Avatar
Bob CTS
I think it took about ~40 times before mine stayed clear. I ususally change it every other month now.
Old Feb 16, 2008 | 10:12 PM
rws.1's Avatar
rws.1
I change mine once a month....
Old Feb 17, 2008 | 07:01 AM
ooh yeah's Avatar
ooh yeah
great write up, I currently have no issues, but I'm going to take your advise anyway. Having no issues does that mean I'm driving her hard enough?
Old Feb 17, 2008 | 09:01 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Change mine every oil change or clucth replacement
Old Feb 17, 2008 | 09:05 AM
Changed my clutch fluid last summer - sure made a difference in the clutch feel.
Don't know what year your car is, but you might want to consider changing the coolant if you haven't already done so.
Old Feb 17, 2008 | 09:42 AM
robsc501's Avatar
robsc501
Hi Nick,
Sounds like you had fun changing the clutch fluid.I to noticed a smoother shift.Remember to throw the un-used fluid bottles away.Next item I would do is bleed all the brakes. You & a friend can do this at home or have a power flush done at the dealer.If you need detailed info for the home e-mail me.
Have a good day.
robsc501
Old Feb 17, 2008 | 10:05 AM
tommybilt's Avatar
tommybilt
I dont shift using the clutch. Should I change mine?
To Change your clutch Fluid
