[Z06] X1 cam-only dyno results
Old 02-19-2008, 09:42 PM
VIPERBLUELX
VIPERBLUELX's Avatar
Default X1 cam-only dyno results
01 Z06, only mods are longtubes, deleted cats, corsa catback(probably no power gain there), X1 cam and a tune by Vengeance.
Old 02-19-2008, 09:52 PM
GubuZ06
Support Corvetteforum!
GubuZ06's Avatar
Sweet! Good #'s. Are your #'s on the low side or are they what you anticipated?
Old 02-19-2008, 10:03 PM
Slow Z06
Slow Z06's Avatar
What elevation are you at?
Old 02-19-2008, 10:25 PM
VIPERBLUELX
They are lower than I'd hoped for, but I was told that's because I have a stock air intake, stock crank pulley, stock throttle body and stock H-pipe?
Around 800 ft
Old 02-19-2008, 10:39 PM
GeorgeZNJ
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
Do you have a baseline dyno number. IMHO the only thing dyno numbers are good for is to show how much power/tq was gained from a particular mod, and to see where in the rpm your power lies. I like to know the increase gained.
Old 02-19-2008, 10:45 PM
VIPERBLUELX
Unfortunately I don't have a baseline. Only reason I have a sheet at all is because I had the car tuned to make sure it was safe after the cam and longtubes.
Old 02-19-2008, 10:46 PM
PeteZ06
PeteZ06's Avatar
St. Jude Donor '07-'08-'09-'10-'11
Those are almost identical numbers what my car pulled when it was X1 cam/headers only.
Old 02-20-2008, 12:20 AM
camvette91
camvette91's Avatar
Any videos to hear the cam?
Old 02-20-2008, 08:18 AM
GeorgeZNJ
GeorgeZNJ's Avatar
I had ECS do my cam, my car had slp longtubes/high flow cats, I had a before and after dyno done, and I got a 70rrwhp increase from the cam on stock heads. I now have American racing headers and high flow cats and in about a month or so I'm getting them to do trick flow heads. Can't wait to see what the increase will be. I have only read great things about Vengance though, I'm sure your cam/tune is optimal.
Old 02-20-2008, 08:35 AM
VIPERBLUELX
Good to know!
Old 02-20-2008, 09:47 AM
RobG03Z06
RobG03Z06's Avatar
St. Jude Donor '08
Congrats...those are good #s for a cam only w/headers on a '01.
Enjoy your ride.
Old 02-20-2008, 10:58 AM
Slow Z06
Slow Z06's Avatar
Im not sure how to feel about your numbers. Good they are, however my car here in Houston dynoed stock at 370 360. untuned with kooks lt, 3" OR and pacecars I gained 8 across the board. same dyno, same conditions. I wonder if 800 ft elevation has anything to do with it.
Old 02-20-2008, 11:09 AM
VIPERBLUELX
You only gained 8rwhp with longtubes, 3" OR and a catback?
Who sells the 3" midpipes?
Old 02-20-2008, 11:24 AM
Slow Z06
Slow Z06's Avatar
midpipes are Kooks also. But i am untuned.
Old 02-20-2008, 02:30 PM
PeteZ06
PeteZ06's Avatar
You also have an '03.
Different cam, lighter valves, better flowing intake and MAF.
On averega '02+ Z06's were pulling 20-30hp more compared to an '01.
I took care of that problem
Old 02-20-2008, 02:34 PM
VIPERBLUELX
stock bottom end?
Old 02-20-2008, 02:58 PM
PeteZ06
PeteZ06's Avatar
stock bottom end?
Yes, for now.
To X1 cam-only dyno results
Old 02-21-2008, 07:30 PM
BUBBAS 01Z06
BUBBAS 01Z06's Avatar
NOT FAIR punk...youre gonna' have more ponies than me now !
Old 02-21-2008, 09:34 PM
fastbluels6
fastbluels6's Avatar
St. Jude Donor '10
nice numbers i just did a hpe cam kit, longtubes w/cats, pully, and injectors and put 448 weather corrected and about 520 crank hp. it was all done by tommy @angermanagement he def did a awsome job!
Old 02-21-2008, 11:12 PM
GeorgeZNJ
GeorgeZNJ's Avatar
I don't have a choice, fastbluels6(post below yours) lives near me.
Quick Reply: [Z06] X1 cam-only dyno results
