Learn something new...everyday?
Old Feb 21, 2008 | 05:34 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default Learn something new...everyday?
OK...still a newbie C5 owner....will someone please tell me what these "catch cans" are???
Old Feb 21, 2008 | 05:35 PM
hotwheels57's Avatar
hotwheels57
Most use them to stop excess oil from entering the intake system...some redneck members use them to spit tobacco into...
This comes from one of the vendors who has an ad for their version of the catch cans on sale. There are several site supporting vendors who sell different versions as well as DIY versions that some elect to use...
http://forums.corvetteforum.com/show....php?t=1928584
Preventing oil vapors from entering the intake manifold is a common problem with built LS motors, and the catch can is a very effective mod thats easy to install. The RevXtreme catch can utilizes a perforated downtube to help disperse the crank case vapors over the entire inner surface for maximum condensation & seperation. Simply plumb inline between your vacum outlet on the intake manifold & the breather system.
Old Feb 21, 2008 | 05:47 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
So these are for only built motors? Stock LS1 does not need?
Old Feb 21, 2008 | 05:55 PM
hotwheels57
That's the general topic of debate...some say it's only necessary for modified engines, others say it's necessary if you drive your stock car hard.
It depends on what you find if you inspect the inside of your throttle body and find evidence of excess oil where it shouldn't be.
My stock LS6 has an ELITE ENGINEERING catch can on it. I check it about every 3 months and find maybe a teaspoon of oil inside.
To me it's like an oil filter magnet, maybe some think it's unnecessary, but it's relatively inexpensive and it's my car to do with as I please.
Old Feb 21, 2008 | 06:20 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
well thats 4 teaspoons less going into your intake each year
Old Feb 29, 2008 | 08:29 AM
TLewis4095's Avatar
TLewis4095
Here is a copy from another post where a tuner modded there PCV system so it is slowly destroying his motor...it explains alot:
Heres the problem with hoses hanging near the ground & pluggin your vacum source. When at speed, one hose will develop negative pressure, and the other positive as the hose has a venturi effect when air is moving past it. What happens then is you are sucking up dirt, sand, water, etc. directly into your valve cover & into the motor internals. I suspect they have no filter on them, correct? Also, if you are not pulling metered vacum at idle & low RPM's the harmfull vapors that are in your crankcase cannot be pulled totally out...only pressure vents so all the unburnt fuel, caustic gasses from blow-by, & moisture will re-condense in your crankcase after the motor cools & contaminate the oil as well as corode internal parts (look at the links in another thread on bearings & see the damage just the unfiltered dust causes). A proper PCV system needs a fresh air source that is filtered, (on the stock OEM setup it is drawn from in front of the throttle body & the main air filer cleans the air pulled) and a vacum source that is metered & valved, such as the PCV valve on a LS1 or the fixed orfice & baffle system in the vally cover of the LS6 & LS2/3/7 design. The problem with the OEM systems on our vettes is it allows oil vapors to be pulled into the intake & robs power & contributes to detonation. The only proper way to correct this w/out sacrificing your engine to premature wear (I have seen motor come in that look like dirt was poured right into the crankcase & no internal part not showing advanced wear & failure from the hoses dangling unfiltered to the ground. Those that have this setup just have to look closly at your oil the next time you change it to see how dark it now comes out compared to when you had the stock system in place) is to modify the system to remove as much of the oil & harmful vapors from the PCV lines before the mist is pulled into the intake. So the most effective mod for NA motors is to add the proper catch can system AND a PCV valve inline to control the amount of vacum pulled & prevent back-flow of the vapors.
The catch can must be of a material that disipates heat effectively, and that eliminates plastic. Auminum or steel are the 2 best. 2nd, the can must be baffeled in such a way as it disperses the vapors to make contact with as much of the cooler outer surface of the can to allow the vapors & oil to condense into droplets that are collected in the bottom of the can. Now 2 forms of oil come through the system....a mist from the fast movong internals in the engine which is pretty easy to trap, and the vapors from the high heat which need the cooler surface area to condense.
So the can has to be large enough to be effective & most I see in use are far to small, allthough there are several good ones on the market. Then the outlet of the can must be located as far up & away from the inlet to prevent vapors from being pulled through before having a chance to cool & condense. You then need a PCV valve to control the amount of vacum.
(this setup uses a perforated down tube to disperse the vapors as completly as possible for contact on the cooler surface & is a 1 qt capacity)
If you have a stroker, big cube build, or run at extended high RPMs you should also add the filtered breather as some have mentioned above (easiest is as an oil fill cap mod) and this will allow a good volume of filtered fresh air in at low RPMs and allow venting of crancase pressure at high RPMs. On a FI application it gets just a little more complicated but the design is very similar.
Shown below is on a Magnacharger application.
So what you have accomplished is a near total elimination of any oil getting into the intake, proper ventalation & breathing, and not subjecting your babies motor to a slow horrible premature death from unfiltered ventelation.
Hope this helps :thumbsup:
Old Feb 29, 2008 | 08:42 AM
B-Vette's Avatar
B-Vette
Hotwheels57 knows what he is talking about young grasshopper.
To Learn something new...everyday?
