Dead Battery Again!!!!
Old Feb 21, 2008 | 09:00 PM
kirby_24's Avatar
kirby_24
Default Dead Battery Again!!!!
Does anyone know of a device that can plug into your car harness somewhere to tell you where you might have an electrical drain on your battery? If I leave our vert set for more than a week without starting it, I always have a dead battery. I just replaced the battery with a very good one with high cranking amps (not from walmart). I let it set for about 10 days & went to start it this morning & nothing at all, not even the interior lights. I already looked at the sunvisor lights & they do not stay on. I am thinking that the starter brushes might be making contact, but don't know. The starter spins fast & doesn't hang up at all, so I am lost for now. Any help would be greatly appreciated in advance.
Old Feb 21, 2008 | 09:09 PM
IMXCITD's Avatar
IMXCITD
there may be nothing wrong......you may need to put a trickle charger on it while you're not driving it so the battery doesn't drain.
Old Feb 21, 2008 | 09:13 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Start here at this link, http://forums.corvetteforum.com/show...ttery+problems #8 post, Bill Curlee, he's your man....than go here http://forums.corvetteforum.com/show....php?t=1946880 and get yourself a "battery tender." #
Old Feb 21, 2008 | 09:18 PM
Bob CTS's Avatar
Bob CTS
I would look into the Battery Tender but first check the draw on the battery while the car is sitting. Bill Curlee will also offer great advise, he is quite a guru when it comes to this stuff.
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
This works for me and cheap!
http://www.lectriclimited.com/battery-butler.htm
Old Feb 21, 2008 | 09:34 PM
jzubik's Avatar
jzubik
St. Jude Donor '13, '15
has ton of info, help me track my battery drain down to the passenger lumbar switch..
Old Feb 22, 2008 | 09:40 PM
kirby_24's Avatar
kirby_24
Thanks for all the advice & links. I will get started this weekend with the ground cleaning. I just purchased a battery tender & plan on installing that as well this weekend. Will let you know what I find out.
To Dead Battery Again!!!!
